how to open STL or STEP file in AutoCAD
LeoImLeo
Message 1 of 9
LeoImLeo
 my colleague used other apps to draw some files for me in STL and STEP format.
However, i found autocad for mac can only open DWG, DXF, DST and DWT now, although files can be exported as STL or STEP. Is there a way to transfer STL or StEp into any AutoCAD readable format?
Replies (8)
Message 2 of 9
maxim_k
Welcome to Autodesk Forums!
Hi @LeoImLeo ,
Please look here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/step-file-into-autocad-2017-mac/m-p/7370365#M27...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
LeoImLeo
Hi @maxim_k
Thanks for the link. Mine is also one time use. Can you transfer these 2 files to DWG files for me? Many thanks.
Message 4 of 9
LeoImLeo
Correct the highlighted errors and try again.
The attachment's 1) leo cell - third draft.step content type (application/octet-stream) does not match its file extension and has been removed.
Message 5 of 9
maxim_k
@LeoImLeo
Create ZIP archive with STEP file and you will be able to attach this archive here.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
maxim_k
Yes, I'll try
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
LeoImLeo
Thanks .  i attached them in ZIP.
Message 8 of 9
maxim_k
Hi Leo,
Here are your files converted to DWG format.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
LeoImLeo
Thanks so much Maxim.
They can be opened finally.
