AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
how to open STL or STEP file in AutoCAD
8 REPLIES 8
Message 1 of 9
LeoImLeo
1574 Views, 8 Replies
 my colleague used other apps to draw some files for me in STL and STEP format.
However, i found autocad for mac can only open DWG, DXF, DST and DWT now, although files can be exported as STL or STEP. Is there a way to transfer STL or StEp into any AutoCAD readable format?
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: LeoImLeo
Welcome to Autodesk Forums!
Hi @LeoImLeo ,
Please look here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/step-file-into-autocad-2017-mac/m-p/7370365#M27...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
LeoImLeo
in reply to: maxim_k
Hi @maxim_k
Thanks for the link. Mine is also one time use. Can you transfer these 2 files to DWG files for me? Many thanks.
Message 4 of 9
LeoImLeo
Correct the highlighted errors and try again.
The attachment's 1) leo cell - third draft.step content type (application/octet-stream) does not match its file extension and has been removed.
Message 5 of 9
maxim_k
@LeoImLeo
Create ZIP archive with STEP file and you will be able to attach this archive here.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
maxim_k
Yes, I'll try
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
LeoImLeo
Thanks .  i attached them in ZIP.
Message 8 of 9
maxim_k
Hi Leo,
Here are your files converted to DWG format.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
LeoImLeo
Thanks so much Maxim.
They can be opened finally.
