How to load Lisp TL and Lisp Nam ( HVAC ) for Cad 2018 on Mac OS !
Message 1 of 20
I using Autocad 2018 on Mac OS, But I don't know how to load lisp Command TL ( Measure distance) and Lisp Nam ( HVAC). Can you tell me  a way to load them ?
Replies (19)
Message 2 of 20
Moshe-A
@Anonymous  hi,
try Tools\Application Load (or key-in APPLOAD)
moshe
Message 3 of 20
vinodkl
Type in the command APPLOAD to load the lisp. Else you could drag and drop the lisp file into Autocad.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 20
imadHabash
Hi and Welcome to AutoCAD Forum,
 You can use the APPLOAD command or the AutoLISP load function to load an application. learn more here . >> Click <<
Imad Habash
Message 5 of 20
Thanks ! But When I use Command Appload to load TL. lisp and enter command TL  measure, It isn't working.
Message 6 of 20
vinodkl
Can you share both the lisp file so that I can see if it works on my system.
Message 7 of 20
Ok. This is link to download file  .lisp.  You can try use it.
http://www.mediafire.com/file/x52n20dnb0uughc/tl.lsp/file
Message 8 of 20
Patchy
Tại vì nó dùng popup, and Mac doesn't like popup ☺
Message 9 of 20
That mean, I can't use it on Mac OS.
Message 10 of 20
vinodkl
I'm able to load the lisp in my system. After loading the lisp did you get the pop up like in the screen shot? and did the window show that the lt.lsp successfully loaded as shown in screenshot? If not the Lisp is not loaded. Try restarting the AutoCAD and see if it works. Though I am using windows I guess it should not look much different in mac.
Message 11 of 20
maxim_k
Hi Hoang,
AutoLISP routine you tried uses VisualLISP, which is not supported in AutoCAD for Mac.
If you need AutoLISP routine for calculating total length of selected lines, polylines, arcs, circles etc., you can try this one:
https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos/m-p/8036223#M31675
It should work in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 20
OK Thanks Maxcim ( Спасибо максим ). I had done. Can you tell me the way to load HVAC ( lisp draw pipe Flexible Air Duct) or Do you know what kind of lisp can draw it?
Message 13 of 20
maxim_k
Can you share HVAC ( lisp draw pipe Flexible Air Duct) routine which you are trying to use? I cannot find it myself.
I'll look at it and will try to figure out the problem.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 20
nguyentuananh.2t
Community Visitor
Community Visitor
Hello bạn mình cũng đang có câu hỏi như bạn để có thể cài Lipnam trên mac os. Bạn đã làm được chưa nếu được chỉ mình được ko ?
Message 15 of 20
maxim_k
Hi @nguyentuananh.2t ,
Can you share Lisp routine you are trying to use on Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 20
thanhdatlc1982
I can't load the HAVC lisp to draw the wind pipe in cad 2022 for mac
@maxim_k
https://siscom.vn/huong-dan-tai-lisp-nam-moi-nhat-100-thanh-cong/
Message 17 of 20
maxim_k
Hi @thanhdatlc1982 ,
This application is only for AutoCAD for Windows, it has the installer which will run only on PC, plus I believe that it has Visual Lisp code which is not supported on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 20
khamtiktok2
Community Visitor
Community Visitor
I want to batch print for macbook ?
Message 19 of 20
khamtiktok2
Community Visitor
Community Visitor
Message 20 of 20
maxim_k
