How to load Lisp TL and Lisp Nam ( HVAC ) for Cad 2018 on Mac OS !
No aplicable
I using Autocad 2018 on Mac OS, But I don't know how to load lisp Command TL ( Measure distance) and Lisp Nam ( HVAC). Can you tell me  a way to load them ?
0 Me gusta
Responder
Soluciones aceptadas (2)
3.525 Vistas
19 Respuestas
Respuestas (19)
Moshe-A
@Anonymous  hi,
try Tools\Application Load (or key-in APPLOAD)
moshe
0 Me gusta
vinodkl
Type in the command APPLOAD to load the lisp. Else you could drag and drop the lisp file into Autocad.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
imadHabash
Hi and Welcome to AutoCAD Forum,
 You can use the APPLOAD command or the AutoLISP load function to load an application. learn more here . >> Click <<
Imad Habash
0 Me gusta
No aplicable
Thanks ! But When I use Command Appload to load TL. lisp and enter command TL  measure, It isn't working.
0 Me gusta
vinodkl
Can you share both the lisp file so that I can see if it works on my system.
No aplicable
Ok. This is link to download file  .lisp.  You can try use it.
http://www.mediafire.com/file/x52n20dnb0uughc/tl.lsp/file
0 Me gusta
Patchy
Solución aceptada
Tại vì nó dùng popup, and Mac doesn't like popup ☺
0 Me gusta
No aplicable
That mean, I can't use it on Mac OS.
0 Me gusta
vinodkl
I'm able to load the lisp in my system. After loading the lisp did you get the pop up like in the screen shot? and did the window show that the lt.lsp successfully loaded as shown in screenshot? If not the Lisp is not loaded. Try restarting the AutoCAD and see if it works. Though I am using windows I guess it should not look much different in mac.
0 Me gusta
maxim_k
Solución aceptada
Hi Hoang,
AutoLISP routine you tried uses VisualLISP, which is not supported in AutoCAD for Mac.
If you need AutoLISP routine for calculating total length of selected lines, polylines, arcs, circles etc., you can try this one:
https://forums.autodesk.com/t5/autocad-for-mac-forum/total-length-in-macos/m-p/8036223#M31675
It should work in AutoCAD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
OK Thanks Maxcim ( Спасибо максим ). I had done. Can you tell me the way to load HVAC ( lisp draw pipe Flexible Air Duct) or Do you know what kind of lisp can draw it?
0 Me gusta
maxim_k
Can you share HVAC ( lisp draw pipe Flexible Air Duct) routine which you are trying to use? I cannot find it myself.
I'll look at it and will try to figure out the problem.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
nguyentuananh.2t
Community Visitor
Community Visitor
Hello bạn mình cũng đang có câu hỏi như bạn để có thể cài Lipnam trên mac os. Bạn đã làm được chưa nếu được chỉ mình được ko ?
0 Me gusta
maxim_k
Hi @nguyentuananh.2t ,
Can you share Lisp routine you are trying to use on Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
thanhdatlc1982
Community Visitor
Community Visitor
I can't load the HAVC lisp to draw the wind pipe in cad 2022 for mac
@maxim_k
https://siscom.vn/huong-dan-tai-lisp-nam-moi-nhat-100-thanh-cong/
0 Me gusta
maxim_k
Hi @thanhdatlc1982 ,
This application is only for AutoCAD for Windows, it has the installer which will run only on PC, plus I believe that it has Visual Lisp code which is not supported on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
khamtiktok2
Community Visitor
Community Visitor
I want to batch print for macbook ?
0 Me gusta
khamtiktok2
Community Visitor
Community Visitor
0 Me gusta
maxim_k
0 Me gusta
