How to Increase the Icon size
Message 1 of 12
I am a new user for AutoCAD in Mac but what i m facing a problem is that the icons to be used to function are so small that i have to keep my eyes close to my screen, so anybody help me to get those icons a little bit bigger than what i have right now ??
Accepted solutions (3)
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Show us a screenshot please.
Message 3 of 12
maxim_k
Welcome to the Autodesk Forums!
You can change icon size for Tool Sets palette and for Status Bar in AutoCAD preferences window (Look and Feel tab):
Use menu AutoCAD -> Preferences, than select "Look and Feel" tab on the left side.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 12
Emmsleys
Hi @Anonymous,
Welcome to the forums!
Try looking over the below help links:
To Change the Appearance of the Drafting Tooltips
Look & Feel Tab (Application Preferences Dialog Box)
Sarah Emmsley
Technical Support Specialist
Message 5 of 12
Hi
I have looked in my look and feel, but for some reason in my version of look and feel there is nothing for changing the icon size,
I'm using 2017 version .
thank you for your help
Message 6 of 12
maxim_k
Welcome to Autodesk Forums!
Hi Paul,
In 2017 version of AutoCAD for Mac you couldn't change the size of the buttons on the ToolSets palette anymore. That is because of the completely new design of the palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 12
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
@maxim_k is correct that AutoCAD for Mac 2017 no longer allows the option of controlling icon size. I should mention however, that if you create your own tools palette, there are some pre-configured icon arrangements (including different sizes) that you can select from. Perhaps this will help with some of your most used tools.
John Vellek
Message 8 of 12
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 9 of 12
Hi @john.vellek
I am also facing the same problem in 2017.
It is getting little inconvenient, and I think Autodesk should not remove such simple options & make things complicated for the end user. However,  is there any option for me to customize the size apart from creating my own tool pallete which is a time consuming process.
Message 10 of 12
john.vellek
Hi @Anonymous,
 I agree that the ability to adjust icon size was a nice option but the last version that allowed this was AutoCAD for Mac 2016.
If you really miss this feature, I encourage you to join the AutoCAD for Mac Customer Council
John Vellek
Message 11 of 12
the "look & feel" section is missing everything below "fade controls".  The icons are way too tiny to make out.  Help!
Message 12 of 12
maxim_k
Hi Jonatan,
Since 2017 version the only one workaround is to use ToolSets palette customization as described here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/how-to-increase-the-icon-size/m-p/7467525#M2832...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
