How to disable Print Completion Notifications and Plot Log files
KevinFellows
Message 1 of 9
KevinFellows
Hi there
Anybody know how to disable plot job completion balloon notifications in Autocad for Mac? I have searched and found a solution for the PC version but there is no tray settings option for the Mac version.
I'd also like to turn off the plot.log file that is saved, but again can only track down guidance for PC versions.
Cheers!
Replies (8)
Message 2 of 9
maxim_k
Welcome to Autodesk Forums!
Hi @KevinFellows ,
There is no official way to disable it, but you can try >>>>this<<<< workaround.
The path to AcInfoBalloonPalette.nib file depend on AutoCAD for Mac version, and in general it looks like:
/Applications/Autodesk/AutoCAD 20xx/AutoCAD 20xx.app/Contents/Resources/Base.lproj/
On Mac you can find the toggle for Plot.log file here:
Use menu File > Batch Publish... to open Batch Publish window, then select Plot Stamp settings button.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
KevinFellows
Thanks Maxim, that's great. I renamed the .nib file as you highlighted with .ttt as the extension and it seems to have solved the pop up. I also tweaked the plot stamp preferences, so far so good! Cheers 🤞😎
Message 4 of 9
RachelGomez161999
Steps are given below-
Select the Start button then chose Settings.
Select Devices.
Select Printers & scanners.
Scroll down to the Related settings section and select the Print server properties link.
Select the Advanced tab.
Uncheck the following boxes:
Show informational notifications for local printers.
Show informational notifications for network printers.
Windows Print Notification Settings
Click OK.
Windows 8, 7, & Server 2012
Note: This option is not available in the Home versions of Windows.
Press and hold the Windows Key, then press R to bring up the Windows Run dialog box.
Type “printmanagement.msc“, then press Enter.
Expand Printer Servers, then right click the name of the computer and select Printer Server Properties.
Uncheck Show Informational Notifications for Local Printers and Show Informational Notifications for Network Printers.
Windows XP
Click the Start > Settings > Printers and Faxes.
Click the File > Server Properties.
Click the Advanced tab.
Notify when remote documents are printed.
Click OK.
Rachel Gomez
***THE POST HAS BEEN EDITED: TIPS NOT RELATED TO AUTOCAD FOR MAC HAVE BEEN CROSSED OUT***
Message 5 of 9
moneumiko
Hi, I'm a new user of AutoCAD for Mac, and I came here looking for a way to turn off the plot notification balloon. So the thing is that it seems there is no access to this file AcInfoBalloonPalette.nib anymore. There is no Contents folder under the app (there is nothing actually), and I do have hidden files turned on. The hard drive search doesn't find this file either.
I'm on the latest version of AutoCAD LT for Mac. Oh, maybe that's because it's LT??
Message 6 of 9
maxim_k
Hi @moneumiko ,
AcInfoBalloonPalette.nib file is still there in 2024 and 2025 versions of AutoCAD for Mac:
I cannot check in LT version, because I don't have access to it, but I believe it should be there too.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
moneumiko
Look at the screenshots, no AcInfoBalloonPalette.nib to be found, and there are no further folders under the Autocad.app.
Message 8 of 9
maxim_k
@moneumiko ,
In macOS all applications are actually folders.
To get inside application folder - right-click on it and select "Show package contents", then you can navigate inside application folder as usual:
Be careful with modifications inside application folder! You can damage application itself.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
moneumiko
Yeeey! Found it, and it worked!! Thank you so much. (I didn't know about the option 'show package contents', I'm new to macOS!)
