How to change layers / properties of multiple blocks to Layer 0 / By Layer on AutoCAD 2018 Mac / Lisp
sickamooseNXET4
sickamooseNXET4
Hey all,
I've seen this question around but the answer seems to be to use a lisp file?
I also don't know how to do that.
I believe this is the lisp I need to use:
http://lee-mac.com/applytoblockobjects.html
However, I don't understand where to download this file to install it? It also says in instructions here:
http://www.lee-mac.com/runlisp.html
that I can copy the lisp and save to a notepad file (Mac's notes don't allow you to save as another file, only export to PDF) could I do this in word?
I'm a complete newb but I run in to the problem of files from architects with block assets being in multiple different layers. Need a quick fix to this so I'm not spending hours updating each block and its inner attributes.
maxim_k
Hi @sickamooseNXET4 ,
Unfortunately, the Lisp procedure you are talking about will not work in AutoCAD for Mac because it uses Visual Lisp that is not supported on Mac.
For the future experience: on Mac, you can use the TextEdit app or any other text editor, or better yet, you can use Visual Studio Code app.
On Mac you can use Lisp from this topic:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/change-a-layer-within-all-blocks/td-...
I attached BL0.lsp file for your convenience.
Save it in some folder inside Home folder on your Mac and use APPLOAD command to load it, then use BL0 command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
