How do I use torient command in autocad for mac ?
albertputinjobs
albertputinjobs
Autocad is not showing the command torient.
http://imgur.com/a/cKaTe
help me.
Replies (9)
maxim_k
TORIENT command is a part of the Express Tools and not available in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
albertputinjobs
Is there any similar command to use in Mac
maxim_k
In attachment you can find AutoLISP routine similar to TORIENT, but with limited capabilities:
- it sets only new absolute rotation, you cannot use "Most Readable" option
- it can rotate TEXT and MTEXT, and text objects inside blocks, but cannot rotate attribute definitions, and blocks with attributes.
APPLOAD it and use new TEXTROTATE command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
albertputinjobs
If possible in future please add torient feature in autocad for Mac also.
maxim_k
It is better to submit your request here:
http://www.autodesk.com/company/contact-us/product-feedback
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
albertputinjobs
can you please give me a step by step procedure on how to do this appload thing ?
maxim_k
Download attached LSP file, in AutoCAD use menu Tools-> Load application, navigate to th email folder where you saved LSP file, select it and pick on Load button. Close APPLOAD dialog window. Use the new command in current drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
albertputinjobs
sorry but unfortunately I didn't find a solution would be great if in a future update Autocad for mac gets a functionality like torient or anything similar to that.
