firs of all sorry for my bad english 🙂 I´m starting to use autocad on a mac, I have autocad 2012 instaled on the computer, and I can't change the scale (size), of the materials (3d environment). Can anyone help me find a way to do it? Or explain to me how can I do that?
Tank you so much 🙂
Unfortunately in mac version of AutoCAD you can not scale (or adjust) materials maps, but here is one trick:
Before assigning material to some object you can scale it down (if you want material to be scaled up) or scale it up (if you want material to be scaled down), then assign material and then scale your object back to original size:
Maxim
HI, thank you for the quick answer 🙂
i'ts possible to do that resize inside autocad? before aplly the texture? Please tell me how to do it, where sould i go to modify the scale?
Thank you once again 🙂
Thanks for the response. I tried but the material is always at the same scale, either increase or decrease a cube for example.
