Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Helix Command
6 REPLIES 6
1495 Views, 6 Replies
Helix Command
Hi all! Despite having just updated my CAD, I am unable to locate the 'Helix' command--either in the draw pull-down or by command. I was wondering if anyone had any info on this. I need to draw a precise helix in 2D. Thank you for any input!
6 REPLIES 6
maxim_k
Welcome to Autodesk Forums!
Hi Todd,
What AutoCAD version are you using?
If it is full AutoCAD 2021 version, then you can find HELIX command:
1/ Tool Set*: Drafting tab > Draw panel > Helix.
*Note: Hidden by default. Click "gear" to display the icon on the tool set panel.
2/ Menu: Draw > Helix
3/ Type HELIX at the command window and hit Return
Look here:
https://help.autodesk.com/view/ACDMAC/2021/ENU/index.html?guid=GUID-5B6FB3FE-F66D-4B09-8744-C8B33E43...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Post a screenshot of your ABOUT command please.
in reply to: maxim_k
Hi Maxim, Thank you for your response! I have AutoCAD 2021 MAC and have followed the three paths you recommended without luck finding the Helix Command. I updated the program to ensure it wasn't an update issue as well. Its very perplexing
Hi Maxim, Thank you for your response! I have AutoCAD 2021 MAC and have followed the three paths you recommended without any luck of finding the Helix Command. I updated the program to ensure it wasn't an update issue as well. Its very perplexing
in reply to: pendean
hello! I've posted a screenshot of the two of the recommended paths to locate the Helix command--showing 'helix' isn't available. When i type helix into the command line the prompt "unknown command" appears. Any ideas on why this command may be hidden?  Thank you!
maxim_k
Todd,
AutoCAD LT installed on your Mac doesn't have HELIX command, as it is "lite" version - no 3D commands.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
