When Im using the hatch tool in solid my Mac Autocad will freeze and crash. I have a Mac m3 pro so the mac system shouldnt be the problem. Anyone has any solution?
It gives me this error code: 782782987 and the app closes.
Thanks.
Solved by maxim_k. Go to Solution.
What if you don't pick internal point but select boundary objects?
Hi @marcelo_arandaU33DM ,
What AutoCAD version doe you use? And what macOS installed on your Mac?
Is this problem present in all your drawings or just in one?
Can you share this drawing here?
I downloaded the latest Autocad version a week ago with all the updates and addicional downloads. I have Sequoia 15.0 on the Mac. I dont know if its a software problem or a corrupt drawing, Im going to share you the drawing.
I cannot reproduce the crash.
What area exactly you need to hatch? Can you clarify?
Try to turn off layers that are not needed to create the hatch.
