I'm taking a CAD class and one of my assignments is to draw the golden Ratio. I understand what it is, but I am confused on how to make a perfect arc. Would someone be able to explain this in-depth, step-by-step? Here is the assignment.
Solved by maxim_k. Go to Solution.
Hi Fiona,
There are a lot of ways to accomplish this task. Here one of them.
1. Start new drawing using acad.dwt template
2. Use UNITS command (menu Format -> Units) to setup Architectural Units:
3. Use menu Tools -> Drafting Settings to setup Snap and Grid on "Snap and Grid" tab of "Drafting Settings" window as follows (Snap and Grid should be turned on):
4. Start PLINE command and pick first point, then use right click context menu to select "Arc" and "Direction"options before picking next point, then pick points from 2 to 6 as showing on this screencast using snap and grid as visual aids:
5. Done!
