AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Fonts not plotting correctly AutoCAD LT for Mac
12 REPLIES 12
Message 1 of 13
PrjctWrks
1619 Views, 12 Replies
I recently updated my Mac to OS Big Sur and I believe I have the most recent version of Autocad LT for Mac (2021) - see screenshot.
I have Helvetica Neue set as my font on the Text Styles after I found out that Helvetica wasn't plotting correctly when using bolds. It was all working fine until I installed Big Sur on my computer.
I changed the font on my text style to other standard fonts like Arial, and when plotting it still doesn't display the bold font properly.
Is there an update coming soon? How can I fix this?
Thank you
Labels (1)
12 REPLIES 12
Message 2 of 13
maxim_k
in reply to: PrjctWrks
Welcome to Autodesk Forums!
Hi Bas,
Your AutoCAD LT is not up-to-date, you need to install >>>>>2021.1 Update<<<<<<<
After installing Update, test printing again.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
PrjctWrks
in reply to: maxim_k
Hi Maxim,
I installed the update and it is still plotting incorrectly. See attached.
Could you please check?
Message 4 of 13
maxim_k
Hi Baz,
You forgot to attach screenshot or it will be better to attach the drawing itself.
You can make attachments only in browser.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
PrjctWrks
Hi Maxim,
Here are the screenshots.
Message 6 of 13
maxim_k
Hi Bas,
I'll be able to check with Big Sur on my side only in the evening.
Can you also attach the drawing or part of it which shows the issue?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 13
PrjctWrks
Hi Maxim,
Of course! Many thanks.
Message 8 of 13
maxim_k
Hi Bas,
Yes, I can reproduce the problem with text in Bold and in Italic on my side.
Looks like this is a bug introduced with new macOS and I don't see any workaround 😞
EDIT: The workaround is to use any other Printer / Plotter installed on your Mac in macOS System Preferences instead of AutoCAD to PDF.pc3 printer. You can use Preview button to create PDF file in this case.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 13
I am having the same issue... I recently updated my Mac and now the fonts will not plot bold or italic, has anyone found a solution ?
Message 10 of 13
maxim_k
Hi @Anonymous
As I wrote >>>>>here<<<< this is a bug ntroduced with new macOS - Big Sur, so the problem can only be solved by the developers or by Apple.
The workaround is >>>>>here<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 13
renz2THRX
Hi Maxim,
Thank you for your suggestion, however it’s still not working on my end. These are the plotters I used.
Message 12 of 13
wei503
in reply to: renz2THRX
We are on it. Please try Maxim's workaround above before we fix it in update.
@renz2THRX , in your case, select the Brother printer, and click Preview button to create a PDF.
Wei Ma
AutoCAD for Mac QA Manager
Message 13 of 13
wei503
in reply to: wei503
2021.1.1 hotfix resolved this issue. Please use the "Check for update" from "AutoCAD 2021" menu to get the hotfix.
Wei Ma
