Font block reference
earthsquare
earthsquare
When i open a 'block with fonts' in  a dwg saved in windows autocad, the block refrences shows an indifferent behaviour (llike extended space between letters, fonts substituted even though the fonts are installed on Mac)
Appreciate a solution.
Regards
Sreejith.S
Landscape Architect
pendean
Community Legend
Community Legend
Friend, Fonts issues are posted all over this forum and are good for you to search yourself and read, I suspect you see the same known OS bahavior everyone else is...
I'll get you started, this fellow is doing the reverse of your task, same problem http://forums.autodesk.com/t5/autocad-for-mac-general/font-subset-not-available-on-mac/td-p/6040687/...
Search for others, it's been answered.
earthsquare
The font subset issue is solved.
The font 'unispace', which displays normal in windows is showing 'expanded' in Mac - auto cad lt.
Sreejith.S
Landscape Architect
earthsquare
Thanks @pendean, I downloaded the unispace font once more an installed.
issue solved.
Sreejith.S
Landscape Architect
maxim_k
Can you specify AutoCAD version you are using and name of the font?
EDIT: I see - the issue is resolved.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
earthsquare
it's autocad Lt for Mac 2016
unispace.
the issue is solved. I downloaded the lastest font.
thanks
Sreejith.S
Landscape Architect
Type a product name
