File Became Read Only after Mojave Update
eduardedy
Message 1 of 14
eduardedy
Maybe someone has an idea about the following:
After Mojave OS update, any drawing which was made before the update became ''Read Only''.
I'm using AutoCAD 2018 and installed the last AutoCAD update.
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
is the problem just the one file, or only files in that folder, or ALL files everywhere and not this deep down?
Message 3 of 14
maxim_k
Hi Eduard Adrian,
Try not to use column view in finder or in "Open DWG" window, use list or icon view instead.
Does this help?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 14
maxim_k
And look here:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 14
eduardedy
I'm using a NAS device to store all the files and yes, all the files have the same problem, apart from if the file is on the Desktop.
Message 6 of 14
eduardedy
Thank you. It's working now!
Best!
Message 7 of 14
This solved it for me. I hope they come out with an update soon. Strange that column view will cause that!
Message 8 of 14
mmany
I'm using a NAS, this solution doesn't  work. It works if I move the files to my desktop, but I can't open files on the NAS no matter what view I'm using in Finder.
Message 9 of 14
mmany
My reply was meant to be to Maxxim's post with the solution.
Message 10 of 14
mmany
Message 11 of 14
maxim_k
Hi Michael,
No problems with opening drawings from NAS (Seagate Personal Cloud) in AutoCAD 2018 on my side. Even with Column view in Finder and in AutoCAD.
Have you logged to NAS as registered user?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 14
mmany
Interesting. I'm using a Synology DS19+ and after the update to Mojave, can no longer open any DWG files stored on it (or better to say they're read-only). I'm logged in and it's working fine. I'm not having any trouble at all opening DWG files on my Macbook's hard drive in any view-mode in Finder.
Message 13 of 14
maxim_k
So it could be some issue related to Synology DS19+ and AutoCAD for Mac.
Are you able to open documents for editing from your NAS in other applications?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 14
mmany
I'm able to open and edit all other file types. DWGs only are opening read-only, and only since the update to Mojave....
