Hello people,
There is any way out there to open a .fxb or a .obj on Autocad 2016 trial version for Mac?
Thanks a lot.
Felipe
Solved by Emmsleys. Go to Solution.
I don't have a fxb file to try.
If you want you can share the file and I can try to set up a VM and the trial version of AutoCAD for the MAC.
Thanks!
I'm just triying to figure what a .fbx exactly is. I want to create 3d models and be able to edit and manipulate them as I want, of course.
@Anonymous wrote:
Thanks!
I added the FBX overview site. FBX is a data exchange technology is a 3D asset exchange format that facilitates higher-fidelity data exchange between 3ds Max, Maya, MotionBuilder, Mudbox and other propriety and third-party software.
I would run a trial for Maya as well if you want to work with FBX/OBJ files specifically. Like Maxim pointed out "FBX and OBJ import is not a feature in AutoCAD for Mac."
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
