Exporting Layer State
I just recently moved to ACad for Mac 2019. In the process i am trying to learn more about various operations & processes. I'd like to export a layer state from one document to another.
The Knowledge base gives the direction to select the layer state to be exported and "click Export". I have arrived at this point. Where is the Export button? I cannot locate it!
pendean
Community Legend
Community Legend
maxim_k
Hi Albert,
Unfortunately AutoCAD for Mac don't have the functionality described in AKN article you mentioned.
But:
- If you have AutoCAD LT for Mac, then the only one way to import/export Layer State is using command line version of -LAYER command:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-2C75A883-10CA-4B6C-96AC-BCD7A779...
An example of such workflow you can see on the video following the link provided by @pendean .
- If you have full AutoCAD version, you can try to use AutoLISP routine from my blog:
https://macacad.wordpress.com/2011/04/11/layer-states-manager-for-autocad-for-mac-visual-friendly-cl...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
A few words about workflow I showed in the video:
1/ create Layer State in the drawing from which you want to export Layer State
2/ open drawing into which you want to import Layer State you created in step #1
3/ in the target drawing from step #2 use -LAYER command with State->Import to import Layer State from the drawing in step #1
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ChrisPreece
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @maxim_k  and @pendean  provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
