Error: syntax error
Error: syntax error
Error: syntax error
Hi Guys !   I want to run a AutoLISP app in AutoCAD.  I am on a Mac. It is possible to run but then while performing it shows an error message saying: " error: syntax error".
The code is in the attachments.
Please help !
maxim_k
Hi @Anonymous,
The code you attached shows another error, when I try to use it in AutoCAD:
"too few arguments in SETQ: (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: "))"
and it is really true:
The statement (SETQ P4 ALTURA (GETDIST "\nIndique a altura da viga: ")) in this routine doesn't assign anything to P4 variable - there should be something between P4 and ALTURA variables: some GET function or some already assigned variable.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
should it work if i insert  (setq p4 (getdist "\nIndique a altura da viga: ")) instead of  (setq p4  altura (getdist "\nIndique a altura da viga: ")) ?
maxim_k
Yes, if the subsequent part of the code is correct.
But (+ ((angle p1 p2) (angle p2 p1) 90) = 180)) seems to be incorrect, because "= (equal to)" also is a function and its signature is (= numstr [numstr ...]. In your case, you are using it incorrectly.
The syntax of "+" function is also incorrect, it should be (+ [number number ...]), but you have something strange.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
