Dynamic Input not working - (Autocad LT 2023) MacOS Ventura13.0
studioVHRZZ
Message 1 of 18
studioVHRZZ
Hi everyone!
When I try to insert a command or to insert a measure (for example when I have to stretch a line), Autocad LT won't let me do it, if I am not on the command line. The dynamic input is active. I compared the Dynamic input's settings with another Autocad version that works and I've already reset all impostations.
Can someone help me?
[ The subject line of this post has been edited for clarity by @pendean Original: Dynamic Input]
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
Not sure I follow, forgive me.
is this a sudden new problem in an old installation?
Or is this a new PC/installation?
Or something else? new mouse? new keyboard?
Is your content on a locked layer?
You have PICKFIRST variable turned off?
Did you try resetting LT yet https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Your LT year version is...? OS is what please?
FYI setting the DYNMODE variable to 3 (not -3, not anything else, "active" means nothing sadly) is the default listed in HELP: see if that gets you part of the way to hat you seek.
Message 3 of 18
studioVHRZZ
Hi pendean and thank you for your reply.
I've installed my license (Autocad LT 2023) on a new MacOS Ventura13.0.
The layer is not locked.
Pickfirst is off.
Autocad already resetted.
DYNMODE is on 3.
Can you help me?
Message 4 of 18
maxim_k
Hi @studioVHRZZ ,
I think - all you need is to install the latest Update to AutoCAD LT 2023.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 18
studioVHRZZ
I fixed it with the update! Thank you very much!!
Message 6 of 18
alina.balkanskaia
Hello, @studioVHRZZ! Great that @maxim_k s answer was helpful to you! That you for marking his answer as the solution - that would be helpful for many other users in the future!
Alina Balkanskaia
Message 7 of 18
janken25
Hi, when I click your link all I get is an article about the update. When I check for updates within AutoCad LT it says I'm up to date. How do I install this update? Many thanks
Message 8 of 18
maxim_k
Hi @janken25 ,
Where do you see the message that AutoCAD LT is up to date?
What AutoCAD LT version do you have?
@janken25 wrote:
.... How do I install this update? Many thanks
You can also download the Update from your Autodesk account:
https://manage.autodesk.com/home
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 18
janken25
Hi, thanks for the reply.
I select Check for updates and then the message is in a dialogue box top right of the Programme.
I have AutoCad LT 2021
Message 10 of 18
maxim_k
Hi @janken25 ,
Yes, your AutoCAD is up-to date.
So you shouldn't have any problems with Dynamic input.
Can you describe your problem in more details?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 18
janken25
Hi Again,
Before I installed Ventura on my Mac, the dynamic input was next to the cursor. It now isn't. If I type a letter, say 'S' for stretch etc the S flashes in the input box next to the cursor and then disappears. I have to unselect Dynamic Input from the icons at the bottom of the AutoCad screen and then commands revert to the Command line.
Message 12 of 18
maxim_k
@janken25 wrote:
.... If I type a letter, say 'S' for stretch etc the S flashes in the input box next to the cursor and then disappears. ...
@janken25 you describe Dynamic input behaviour in Ventura without the latest Update installed.
Can you check "Product version" in "About AutoCAD" window?
Or check "_VERNUM" System variable.
What version do you see?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 18
janken25
Many thanks
Message 14 of 18
maxim_k
Ken,
After installing the latest Update which fixes compatibility issues with macOS 13 Ventura, the Product Version should be: 2021.3, but you have 2021.2.2.
So the latest Update is not installed...
Not sure why AutoCAD gives "Your product is up-to-date!" notification.
You can download 2021.3 Update from your Autodesk account:
https://manage.autodesk.com/products
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 18
maxim_k
Here:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 18
janken25
Many thanks. I'll give that a try and report back ASAP
Message 17 of 18
janken25
Hi Maxim, I've downloaded the latest version of the software and all working fine now. Many thanks for your help.
Message 18 of 18
maxim_k
It's nice to hear that I was able to help you.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
