Dynamic Input not working - (Autocad LT 2023) MacOS Ventura13.0
studioVHRZZ
studioVHRZZ
Hi everyone!
When I try to insert a command or to insert a measure (for example when I have to stretch a line), Autocad LT won't let me do it, if I am not on the command line. The dynamic input is active. I compared the Dynamic input's settings with another Autocad version that works and I've already reset all impostations.
Can someone help me?
[ The subject line of this post has been edited for clarity by @pendean Original: Dynamic Input]
0 Me gusta
Responder
Soluciones aceptadas (2)
1.694 Vistas
17 Respuestas
Respuestas (17)
pendean
Community Legend
Community Legend
Not sure I follow, forgive me.
is this a sudden new problem in an old installation?
Or is this a new PC/installation?
Or something else? new mouse? new keyboard?
Is your content on a locked layer?
You have PICKFIRST variable turned off?
Did you try resetting LT yet https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Your LT year version is...? OS is what please?
FYI setting the DYNMODE variable to 3 (not -3, not anything else, "active" means nothing sadly) is the default listed in HELP: see if that gets you part of the way to hat you seek.
0 Me gusta
studioVHRZZ
Hi pendean and thank you for your reply.
I've installed my license (Autocad LT 2023) on a new MacOS Ventura13.0.
The layer is not locked.
Pickfirst is off.
Autocad already resetted.
DYNMODE is on 3.
Can you help me?
0 Me gusta
maxim_k
Solución aceptada
Hi @studioVHRZZ ,
I think - all you need is to install the latest Update to AutoCAD LT 2023.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
studioVHRZZ
Solución aceptada
I fixed it with the update! Thank you very much!!
0 Me gusta
alina.balkanskaia
Hello, @studioVHRZZ! Great that @maxim_k s answer was helpful to you! That you for marking his answer as the solution - that would be helpful for many other users in the future!
Alina Balkanskaia
0 Me gusta
janken25
Hi, when I click your link all I get is an article about the update. When I check for updates within AutoCad LT it says I'm up to date. How do I install this update? Many thanks
0 Me gusta
maxim_k
Hi @janken25 ,
Where do you see the message that AutoCAD LT is up to date?
What AutoCAD LT version do you have?
@janken25 wrote:
.... How do I install this update? Many thanks
You can also download the Update from your Autodesk account:
https://manage.autodesk.com/home
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
janken25
Hi, thanks for the reply.
I select Check for updates and then the message is in a dialogue box top right of the Programme.
I have AutoCad LT 2021
0 Me gusta
maxim_k
Hi @janken25 ,
Yes, your AutoCAD is up-to date.
So you shouldn't have any problems with Dynamic input.
Can you describe your problem in more details?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
janken25
Hi Again,
Before I installed Ventura on my Mac, the dynamic input was next to the cursor. It now isn't. If I type a letter, say 'S' for stretch etc the S flashes in the input box next to the cursor and then disappears. I have to unselect Dynamic Input from the icons at the bottom of the AutoCad screen and then commands revert to the Command line.
0 Me gusta
maxim_k
@janken25 wrote:
.... If I type a letter, say 'S' for stretch etc the S flashes in the input box next to the cursor and then disappears. ...
@janken25 you describe Dynamic input behaviour in Ventura without the latest Update installed.
Can you check "Product version" in "About AutoCAD" window?
Or check "_VERNUM" System variable.
What version do you see?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
janken25
Many thanks
0 Me gusta
maxim_k
Ken,
After installing the latest Update which fixes compatibility issues with macOS 13 Ventura, the Product Version should be: 2021.3, but you have 2021.2.2.
So the latest Update is not installed...
Not sure why AutoCAD gives "Your product is up-to-date!" notification.
You can download 2021.3 Update from your Autodesk account:
https://manage.autodesk.com/products
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Here:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
janken25
Many thanks. I'll give that a try and report back ASAP
0 Me gusta
janken25
Hi Maxim, I've downloaded the latest version of the software and all working fine now. Many thanks for your help.
0 Me gusta
maxim_k
It's nice to hear that I was able to help you.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
