& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi, when drawing in paper space, the cursor jumps from object to object and nothing in between. This was not the case previously, I think I have clicked on a setting. Can anyone help?
Hi @Red_Neil ,
Do you have SNAP enabled in Paper space?
Do you have this problem in all of your drawings?
Can you show screen recording of the issue?
This is a vid of the issue, I seems to have something to do with ’Nodes’?
The ‘Roadhouse’ drawing shows how my other files behave, the ’Typsie’ drawing is more ‘clunky’ as you can see.
Snap vs Object Snap are different.
When you enter at the command prompt:
Snapmode
Is this set to 0 or 1?
If 1, enter 0 and see if that makes a difference.
And thanks to @maxim_k as well… cheers!!!
Thanks to you both - Cheers
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
