Disable 3D orbit
Disable 3D orbit
jvsk_V9TUMDGBR3BE
Disable 3D orbit
jvsk_V9TUMDGBR3BE
By accident I constantly activate 3D orbit by pressing Shift+Middle Button.
Is there any way to turn that shortcut off? It is driving me nuts!
Best, Jens
maxim_k
Hi @jvsk_V9TUMDGBR3BE ,
I'm afraid - it is impossible on Mac.
But you can try "workaround" - set System Variable MBUTTONPAN=0, then you will see OSNAP context menu instead of 3DORBIT. You also won't be able to pan using the middle mouse button.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jvsk_V9TUMDGBR3BE
Thanks for your answer, well maybe it could work, but I would need to fix a new hot-key for panning then-but maybe that just might be the workaround I need.
maxim_k
@jvsk_V9TUMDGBR3BE wrote:
...but I would need to fix a new hot-key for panning then....
Use Spacebar panning - press Spacebar an then pan with mouse as usual. This works inside commands.
As for me - I prefer to use mouse wheel zoom out/in instead of pan.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ccombs7TVNT
You could go into CUI>Mouse Buttons>Shift+Click>Button 3 and either assign a new command or delete button 3 altogether to where it doesn't do anything when you hit shift+mouse wheel.
maxim_k
Hi @ccombs7TVNT ,
Unfortunately, changing the behavior of mouse buttons using a CUI command is not possible in AutoCAD for Mac...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
