Dimensions will not show unless objects are selected
I have been having a problem with AutoCAD 2016 on my MacBook.
The dimension lines will not show unless I select the objects that they are defining.
I have inserted some screenshot below, any help is greatly appreciated!
David Close.
pendean
Community Legend
Community Legend
Post your DWG file, let's look at the source for ourselves.
maxim_k
Welcome to Autodesk Forums!
It appears you are using wrong tool to put dimensions.
Instead of using these buttons in Annotation tab of Tool Sets palette (DIM, DIMLINEAR and other commands):
You are using these buttons on Drafting tab of Tool Sets palette (parametric dimensions):
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Here you go hope it helps!
Thank you!
maxim_k
The answer is here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/dimensions-will-not-show-unless-objects-are-sel...
You are using parametric dimensions instead of regular dimensions.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
