Anuncios
Dimensions will not show unless objects are selected
No aplicable
I have been having a problem with AutoCAD 2016 on my MacBook.
The dimension lines will not show unless I select the objects that they are defining.
I have inserted some screenshot below, any help is greatly appreciated!
David Close.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.221 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
Post your DWG file, let's look at the source for ourselves.
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
It appears you are using wrong tool to put dimensions.
Instead of using these buttons in Annotation tab of Tool Sets palette (DIM, DIMLINEAR and other commands):
You are using these buttons on Drafting tab of Tool Sets palette (parametric dimensions):
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Here you go hope it helps!
Thank you!
0 Me gusta
maxim_k
Solución aceptada
The answer is here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/dimensions-will-not-show-unless-objects-are-sel...
You are using parametric dimensions instead of regular dimensions.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
