DELETE key not working...
I am using AutoCAD 2017 on Mac through Parallels, so my computer is running through Windows. However, I am having an issue using the DELETE key on my keyboard. I have seen what others have been saying about this issue and suggesting to set PICKFIRST to 1, but it was already set to 1 once I installed it. I also saw something about setting QAFLAGS to 0, but that command doesn't seem to exist on AutoCAD 2017, or it might have a different name. Is there any way to get the DELETE button to work? I appreciate any help on this problem!
rkmcswain
So you are positive that PICKFIRST=1 and QAFLAGS=0?
QAFLAGS is not documented, but it will be recognized if you type it in.
So is this AutoCAD for Windows or AutoCAD for MAC?
R.K. McSwain     | CADpanacea | on twitter
paullimapa
How do you know in your AutoCAD 2017 that the command QAFLAGS does not exist?
Did you try typing at AutoCAD's command prompt with no other commands running: QAFLAGS
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Yes, the only command that shows up available is “AFLAGS”. Is this the command that I should be looking for?
maxim_k
Welcome to Autodesk Forums!
Hi Francisco,
Delete key wouldn't work in Parallels virtual machine as Del key on PC unless you will be using it in a combination with Fn key on your Mac keyboard. So if you want to erase something - select it and use Fn+delete key combination.
And, of course, PICKFIRST should be 1.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you so much, it worked!
