Binding Image into DWG
Message 1 of 18
Hi Im looking to bind an image file into a dwg. e.g. JPG
Is this possible to do in MAC LT ?
I've found this post that suggests using PASTESPEC but this command does not seem to exist in MAC LT ? - https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/binding-im...
Only other workaround i can think of is making it a PDF and binding that way? Anyone have any suggestions
Tom
Replies (17)
Message 2 of 18
john.vellek
Hi @Anonymous,
Unfortunately, binding an image file is not possible on a Mac as this relies on OLE technology which is part of the Windows environment.
What is in this image? Is it something you can vectorize and then insert?
John Vellek
Message 3 of 18
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. If you have an image that suits itself to being a vector drawing, I am happy to try and convert it for you. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 4 of 18
RMHartmann
I periodically check the AutoCAD Mac forums to see if image embedding can somehow be enabled in AutoCAD for Mac...
I get that in AutoCAD for Windows it is possible because OLE, and that "OLE technology ... is part of the Windows environment," and for this reason is not possible on Macs. However, as AutoCAD for Mac has improved greatly over the years, I keep hoping. The lack of an OLE compatible embedding feature is one of the few things that still gets in the way of seamless sharing of DWG files between Windows and Mac users.
I looked for an AutoCAD Mac "Ideas" list on Autodesk's website to request this feature, but could not find the list, so I am posting this idea here: If bringing OLE to Mac is hopeless, how about turning it around -- could there someday be a way to embed images on the Mac side that would be compatible with the Windows side?
Message 5 of 18
it's almost 2019 and we still can't open OLE or attach images on Mac... When is this getting resolved?
Message 6 of 18
john.vellek
HI @Anonymous,
I doubt OLE will ever work on the Mac side of things as it is really a Windows-based technology.
I agree however that a means to do this would be very helpful.
I encourage you  to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email autocad.beta@autodesk.com or autocad.lt.council@autodesk.com
John Vellek
Message 7 of 18
maxim_k
Hi Guilherme,
I'm afraid - never. That is because OLE technology is a part of operating system (OS) and it is not available in macOS.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 18
Understandable, but no other form of binding image into DWG on Mac is what I don't fully comprehend.
Message 9 of 18
dgorsman
OLE doesn't work that great for "embedding images" on the Windows side either.
Trying to shoehorn that amount of data (even with good compression, such as PNG) into a DWG file is difficult without the file size bloating up like a week-old corpse in the tropics.  And it's not *that* helpful given that existing image file formats are available with appropriate viewers and editors.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 10 of 18
pendean
Community Legend
Community Legend
Amen!
Message 11 of 18
RMHartmann
..."bloating up like a week-old corpse in the tropics." Hah, good analogy (albeit a little gross)...
I totally agree that the inefficiency that currently exists with image embedding is a concern, but I would say that embedding images is helpful for title block logos if nothing else.
I have worked on projects that did not allow any attachments or xrefs, yet still wanted DWG format, so everything had to be embedded or "bound" (or do we say "binded" as past tense of the "bind" command for xrefs?). Anyway, the title block logos got embedded using one of our Windows work stations, but we actually had PDFs in many sheets before we were made aware of the requirement. So then we had to convert the PDFs to JPGs because even Windows can't embed PDFs. That was annoying.
Maybe by confining the image file type to PDF or some other, we could have a cross-platform image embedding solution in order to simplify DWG distribution. That's really my hope: forget the Windows-specific OLE embedding method -- come up with a method that is more efficient and can be used on either Mac or Windows.
Message 12 of 18
j.gonzalez.f.8
Observer
Observer
2021 and still nothing ole images
Message 13 of 18
pendean
Community Legend
Community Legend
@j.gonzalez.f.8 OLE is a WindowsOS feature/ability https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
"MAC OS has no OLE ability. AutoCAD for MAC has no OLE, since it is not found in the MAC OS. Applications linking is done at the OS level: otherwise every application will need custom code for each specific other program and the nightmare of coding will grow exponentially and then really be unstable."
Now you know.
Message 14 of 18
maxim_k
Hi @j.gonzalez.f.8 ,
FYI - in AutoCAD 2021 for Mac and later versions you can see OLE images inserted into the drawing in AutoCAD for Windows.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 18
You can see OLE inserted but can you actually embed images in Autocad for Mac?
Message 16 of 18
maxim_k
Hi @Anonymous,
No
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 18
j.gonzalez.f.8
Observer
Observer
excelent thank you
Message 18 of 18
RMHartmann
@j.gonzalez.f.8
This other thread has additional info about OLE support for embedding images in Mac version. There is a process that has to take place on a Windows PC to make images visible on Mac:
https://forums.autodesk.com/t5/autocad-for-mac-forum/ole-visibility-in-autocad-autocad-lt-2021-for-m...
