AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Degree symbol not plotting correctly into PDF - shows up as a line of dots
11 REPLIES 11
Message 1 of 12
alison5V4UE
724 Views, 11 Replies
Hi all,
I can't seem to figure out how to correct the issue of the degree symbol plotting as dots when i plot to a PDF file.
I have been reading all the answers to " capture all " the fonts but i cannot for the life of me find that option to select in my AutoCAD 2023.
Attached screenshot of my plot window. No where do i see a settings, or additional tabs to find the " capture all fonts "
Thank you!!
Labels (4)
11 REPLIES 11
Message 2 of 12
pendean
in reply to: alison5V4UE
I don't see a screenshot from your PDF actually showing the problem: can you share that here now?
Message 3 of 12
pendean
Semantics throwing you for a loop by chance? Capture>Embed , tomato>Tomahtoe 🙂
Message 4 of 12
maxim_k
Hi @alison5V4UE ,
Please provide additional information:
- What macOS version is installed on your Mac
- What font are you using for the Text Style that doesn't display the degree symbol correctly when saved to PDF?
Can you share drawing file with this problem?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 12
alison5V4UE
in reply to: pendean
Degree symbol should be in the top line above " appliance door" and it knocks out that whole row of text
Message 6 of 12
alison5V4UE
in reply to: maxim_k
Version is AutoCAD LT 2023 on mac
Font " missing" is Avenir - book
Attached CAD file.
Thanks!
Message 7 of 12
maxim_k
@alison5V4UE
Have you installed >>>>this<<<< Update?
What macOS is installed on your Mac?
What Mac model do you have?
I don't have problems on my Mac:
Try to open attached PDF.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 12
alison5V4UE
Just downloaded the update and still no luck!
imac M1, 2021
MacOS - Ventura 13.4
I can open your attached PDF correctly, font shows up fine.
I always " publish" to PDF from the layout tabs - never had an issue before but maybe something in the settings has changed here?
Message 9 of 12
maxim_k
Tomorrow I'll try on Mac mini M1, but I don't have Ventura on it, so will test on Monterey.
Meanwhile - can you share PDF file you get from this drawing?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 12
maxim_k
Hi @alison5V4UE ,
I tested your drawing on Mac mini M1 with macOS Ventura and didn't find any problems.
Can you open attached PDF?
Do you see the issue?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
alison5V4UE
@maxim_k  Yes i can open your PDF no problem and see the text correctly.
Still stumped! Any other suggestions here?
Appreciate it, thanks.
Message 12 of 12
maxim_k
Hi @alison5V4UE ,
Please create PDF with Preview button in Print window and attach it here.
Attach also a screenshot of the print settings at the moment when you create the preview.
And one more question: if you open PDF with Preview app - do you see the same problem?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
