Just ran the macro to get you some additional info. See below:
1 - Using a freshly opened file, I got the command line to pop-up on the first try. See below for the contents of the command line.
2 - When AutoCAD crashes it completely closes, I have to restart and go through the welcome screen and drawing recovery dialog to get going again. I also get the below recovery dialog on crash.
3 - I have not tried this option.
Dialog appears on crash:
Command line contents after a successful run of macro (commandline pops up where it was previously hidden):
Command: draworder
Select objects: previous
7 found
Select objects:
Enter object ordering option [Above objects/Under objects/Front/Back] <Back>: back
Command: -la
-LAYER
Current layer: "-CALCS"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: thaw
Enter name list of layer(s) to thaw: l-pl-groundcover
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: set
Enter layer name to make current or <select object>: l-pl-groundcover
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: freeze
Enter name list of layer(s) to freeze or <select objects>: *
Cannot freeze layer "L-PL-GROUNDCOVER". It is the CURRENT layer.
Command: _select
Select objects: _auto
Select objects: all
12 found
Select objects:
Command: draworder
12 found
Select objects:
Enter object ordering option [Above objects/Under objects/Front/Back] <Back>: front
Command: -la
-LAYER
Current layer: "L-PL-GROUNDCOVER"
Enter name list of layer(s) to thaw: l-pl-groundcover-e
Enter layer name to make current or <select object>: l-pl-groundcover-e
Cannot freeze layer "L-PL-GROUNDCOVER-E". It is the CURRENT layer.
Command: _select
Select objects: all
2 found
Select objects:
Command: draworder
2 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-GROUNDCOVER-E"
Enter name list of layer(s) to thaw: l-furniture
Enter layer name to make current or <select object>: l-furniture
Cannot freeze layer "L-FURNITURE". It is the CURRENT layer.
Command: _select
Select objects: all
23 found
Select objects:
Command: draworder
23 found
Select objects:
Command: -la
-LAYER
Current layer: "L-FURNITURE"
Enter name list of layer(s) to thaw: l-features
Enter layer name to make current or <select object>: l-features
Cannot freeze layer "L-FEATURES". It is the CURRENT layer.
Command: _select
Select objects: all
53 found
Select objects:
Command: draworder
53 found
Select objects:
Command: -la
-LAYER
Current layer: "L-FEATURES"
Enter name list of layer(s) to thaw: l-pl-shrubs
Enter layer name to make current or <select object>: l-pl-shrubs
Cannot freeze layer "L-PL-SHRUBS". It is the CURRENT layer.
Command: _select
Select objects: all
95 found
Select objects:
Command: draworder
95 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-SHRUBS"
Enter name list of layer(s) to thaw: l-pl-label
Enter layer name to make current or <select object>: l-pl-label
Cannot freeze layer "L-PL-LABEL". It is the CURRENT layer.
Command: _select
Select objects: all
96 found
Select objects:
Command: draworder
96 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-LABEL"
Enter name list of layer(s) to thaw: l-pl-shrubs-e-shade
Enter layer name to make current or <select object>: l-pl-shrubs-e-shade
Cannot freeze layer "L-PL-SHRUBS-E-SHADE". It is the CURRENT layer.
Command: _select
Select objects: all
1 found
Select objects:
Command: draworder
1 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-SHRUBS-E-SHADE"
Cannot freeze layer "L-PL-SHRUBS-E". It is the CURRENT layer.
Command: _select
Select objects: all
1 found
Select objects:
Command: draworder
1 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-SHRUBS-E"
Enter name list of layer(s) to thaw: l-pl-trees
Enter layer name to make current or <select object>: l-pl-trees
Cannot freeze layer "L-PL-TREES". It is the CURRENT layer.
Command: _select
Select objects: all
26 found
Select objects:
Command: draworder
26 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-TREES"
Enter name list of layer(s) to thaw: l-pl-trees-e-shade
Enter layer name to make current or <select object>: l-pl-trees-e-shade
Cannot freeze layer "L-PL-TREES-E-SHADE". It is the CURRENT layer.
Command: _select
Select objects: all
1 found
Select objects:
Command: draworder
1 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-TREES-E-SHADE"
Cannot freeze layer "L-PL-TREES-E". It is the CURRENT layer.
Command: _select
Select objects: all
3 found
Select objects:
Command: draworder
3 found
Select objects:
Command: -la
-LAYER
Current layer: "L-PL-TREES-E"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: a
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: r
Enter name of layer state to restore or [?]: temp
Regenerating model.
Command: re
REGEN Regenerating model.
Command:
