Copy/Paste from one file to another is inserting temp file path?
Message 1 of 15
i searched 😉
when i copy geometry in one file and try to paste into another it inserts a temp file path.
kind of new. thanks.
Replies (14)
Message 2 of 15
maxim_k
Welcome to Autodesk Forums!
Please specify AutoCAD version and macOS version you have on your Mac.
Does this happens with all drawings, even newly created?
Have you tried to restart AutoCAD? - Use QUIT command and launch AutoCAD again.
Restart your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 15
no dice. running 2017 latest hotfix
Message 4 of 15
maxim_k
You have not answered my question :
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 15
sorry, yes. shutdown, reopen, same thing happens. just a filepath. thank you for replying.
Message 6 of 15
pendean
Community Legend
Community Legend
Post a video on your screen doing these things, let's watch you and your screen in action. You can install and use the free Autodesk Screencast app to create the video https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Message 7 of 15
edit: i just reset autocad to defaults and it works. i didn't know i could do that.
this is bizarre.
if i go and open the file at the pasted path it is the geometry. don't have this problem in 2016LT.
https://screencast.com/t/vu10SEI9pu
Message 8 of 15
maxim_k
So, the issue is resolved by resetting AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 15
yeah, sorry waste your time.
Message 10 of 15
actually it wasn't solved. it started doing it again. but i did find out what was causing it.
i disabled a clipboard management app called Copied and it works now.
so is this a bug with AutoCAD or Copied?
thanks again
Message 11 of 15
maxim_k
I tried Copied on my side and everything seems to work correctly in AutoCAD with default settings in Copied.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 15
ahhhh, it's the "plain text mode" setting in Copied that is causing the issue i think.
Message 13 of 15
maxim_k
I also tried with "plain text mode", but it doesn't affect AutoCAD in my case.
I have not tried PasteHelper - maybe it affects AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 15
really!?! maybe it's a combination of different clipboard managers i have installed that you don't?
the only other apps i have that monitor the clipboard are Alfred and Unclutter. i just shutdown my computer, I'll have to check and see if anything else is mucking with the clipboard next startup.
over here it is definitely the "plain text" setting that triggers the issue.
do you have Alfred or Unclutter?
what is different about acad's copy/paste that is different than other apps?
glad your helping me, if you are like me, these things turn into a game, i love trying to figure out why.
Message 15 of 15
maxim_k
No, I haven't.
Obviously, there are some differences, but I do not know exactly what is under the hood. For example if you will copy something from AutoCAD and will try to paste to some other application on Mac, you will get only the path (in plain text) to the temporary dwg file containing the objects you copied from AutoCAD. Maybe that is because there is no OLE technology in macOS, and only AutoCAD can recognize real DWG data in the link, saved in clipboard.
Clipboard managers can potentially destroy some bits in the data copied to clipboard from AutoCAD and as the result AutoCAD cannot recognize it correctly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
