Compatibility new MacBook M1 chip
Message 1 of 78
Does anyone have any information on whether the new M1 chip MacBooks will get support?
Replies (77)
Message 41 of 78
robbruce
Hi
Hope you can help. I am about to upgrade my MacBook air as it is 8 years old and crashes. I am told the new MacBook air comes with the new M1 chip and that I can run autocad lt 2021 using something called rosetta 2? Please can you advise me if this is true and it there are any performance issues i should know about before spending money on a new computer?
I do most of my cad work on an iMac but the air is very good for when i am away from the office.
Thanks!
Rob
Message 42 of 78
maxim_k
Hi Robert,
I tried to answer your question here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-for-macs-with-new-apple-m1-chip/m-p/...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 43 of 78
robbruce
Thanks very much for such a quick response which was helpful.
Rob
Message 44 of 78
Hi Rob,
I had an issue with M1 until I made the latest upgrade and now it runs perfectly.
Message 45 of 78
robbruce
Thanks for getting back to me. That is helpful, assume you mean the latest upgrade of autocad or do you mean on your mac?
Rob
Message 46 of 78
maxim_k
Hi Rob,
@robbruce wrote:
..... assume you mean the latest upgrade of autocad or do you mean on your mac?
The latest Update for AutoCAD:
AutoCAD LT for Mac 2021.1.1 Hotfix
and
AutoCAD for Mac 2021.1.1 Hotfix
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 47 of 78
robbruce
That's perfect thank you, I can easily get those so I'm all set.
Thanks for all your help.
Message 48 of 78
stefanocibelli
I just bought a Mac Book Pro 13” M1 16gb, is AutoCAD compatible with M1 chip now? Thanks!
Message 49 of 78
maxim_k
Hi @stefanocibelli ,
AutoCAD for Mac 2021 and 2022 are supported on Apple Mac models with M series chip under Rosetta 2 mode.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 50 of 78
robbruce
Hi
I updated to latest autocad for mac 2022 on my new MacBook air with M1 chip and when `i try to open cad get a message saying "license checkout timed out. What do you want to do?"
Any suggestions on what I can do to fix this? I only have one license but I had logged out of my autodesk account on my iMac which I also use.
Rob
Message 51 of 78
maxim_k
Hi Robert,
Please look at this AKN page:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
And try the solutions described there.
You can also ask your question on the Installation & Licensing Forum
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 52 of 78
robbruce
Thanks Maxim
Helpful as always.
Rob
Message 53 of 78
abitofcad
Hi @maxim_k
Is there any timeline for native AutCAD compatibility for the M1 chip?   i.e. when it will no longer have to run through rosetta?
The possibility of this chip is really exciting, but not when it requires a translator that basically matches the Intel chipset.
Thanks.
Message 54 of 78
maxim_k
Welcome to Autodesk Forums!
Hi @abitofcad ,
Autodesk never reveals its plans, so the timing of the release of AutoCAD for Mac with native support for the M1 chip is unknown....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 55 of 78
k.mozuraitis
I have noticed the same issue with License time timeout every time after MacOS is updated.
The problem solves by itself just after simple Restart of machine.
Message 56 of 78
PaulMarsh8527
Yes I noticed the same with a recent MacOS upgrade, the License time out prompt appeared while using AutoCad LT 2021. As I downloaded a couple of AutoCad LT service packs, as advised in a different forum, the AutoCad program was restarted but frustratingly still went through the same process of shutting down of the program.
It was only after I had restarted the Mac Mini it now seems to have been sorted in avoiding the same issue.
Message 57 of 78
rsanghvi
Hello Everyone,
I just wanted to know, whether Autocad  for Mac runs as fluently and smoothly on M1 Mac as like on Intel Macs?
Your answer and experience would be a great help, as I am planning to buy new MacBook Pro, which is days away from the release.
Thanks…
Message 58 of 78
maxim_k
Hi @rsanghvi ,
Yes, for the moment it runs on M1 Mac with macOS Big Sur the same way as on Intel Macs.
But keep in mind that new 2021 M1 Macs will sheep with new macOS Monterey.
Despite the fact that the developers will prepare an update for AutoCAD that will ensure compatibility with the new system, no one can know for sure how the system update will affect AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 59 of 78
rsanghvi
Hello Maxim,
Thanks a lot for a quick reply. Glad to hear that the current AUTOCAD Version is running as smoothly on M1 Mac as on Intel Macs.
I will wait to buy the new MacBook Pro, till all the compatability  issues get over for MacOS Monterey, as well as with new M series chip.
Thanks once again…
Message 60 of 78
rsanghvi
has anyone tried out new M1 pro or M1 max MacBook Pro  with AUTOCAD 2022?
if yes, can you Pl. share your experience with the performance and compatibility?
