Compatability
Compatability
Message 1 of 10
Compatability
I have a very new 2011 iMac with the max available memory, HDD and processor speed, yet I can't get AutoCAD to load.  I am a student and downloaded the student version.  What could be wrong ?
Replies (9)
Message 2 of 10
maxim_k
Although you provided not enough information (for example, what you see, when you try to start AutoCAD), consider to look at these links:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15860222&linkID=15839490
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16276182&linkID=15839490
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16158903&linkID=15839490
http://macacad.com/2010/11/25/autocad-for-mac-and-adobe-software/
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
Thanks for input. I changed my language settings to English (British) which, as an Australian I find a bit offensive :), and I believe that all the other issues should be OK.  I could not find a file called "FLEXnet Publisher" on my iMac (will look again), despite using Adobe Acrobat Pro.
The symptom is that I get the initial AUTOCad boot screen, then it quits without any error message.
This is very annoying because I'm a long-time user of this software and want to stop the need to go to my Windows partition every time I need to use CAD.  The more I can avoid Windows the happier I will be !
All help most appreciated....
DW
Message 4 of 10
maxim_k
Hi DW,
What you see in Console app during AutoCAD startup? (Applications->Utilities->Console.app)
Have you tried also to create new account on your Mac and try to start AutoCAD in it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 10
I looked at Console and tried to load CAD and only got this :
10/06/11 4:04:51 PMlmuopen[716]Launching: /Applications/Autodesk/Adlm/R1/LMU.app/Contents/MacOS/LMU
(it didn't load)
But looking at previous I have this (hundreds of lines of this):
10/06/11 8:54:19 AM[0x0-0x28028].com.autodesk.Remove_AutoCAD[398]Waiting for Process Remove AutoCAD with PID 398 to finish ...
(I did remove and reinstall without success).
Message 6 of 10
Thanks, but also logging on as anew account had the same problem and the same Console entry.
Message 7 of 10
maxim_k
Have you found FLEXnet Publisher folder?
Be attentive - it is not located in your home folder, but in Library folder, that resides in root of HD:
"/Library/Preferences/FLEXnet Publisher"
M
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
It worked !
Except now the system tells me that I can't live in Australia, or my alternative address in the UK, as the product cannot be activated if I have either address !
What's happening...why does it all have to be so hard !
Message 9 of 10
maxim_k
Congratulations!
But could you enplane what do you do exactly - some additional changes in Language and Text pane of System preferences?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 10
I did what you suggested with the folder in Library (FLEXnet Publisher), I actually moved the whole folder out to the desktop, removed AutoCAD, reinstalled it, executed then copied the file associated with Adobe Acrobat back into the sub-folder.
But activating the software is now the problem.
