Change dropdown menu?
colekartom
colekartom
I was wondering if it was possible to change the dropdown menu for the "arc" command.  I am using AutoCad LT 2017 for Mac.  As it stands, when I choose "arc" from the toolkit ( the group of icons on the right of my screen) I am prompted to enter the first point of the arc.  I am also able to use the dropdown menu that will let me choose the center of the arc.  I would like my option to always be "center" and have the "first point" be in the dropdown menu instead.  In other words, switch them.  Is this possible?  Thanks
maxim_k
Hi Karrie,
You cannot change the default drop-down button, but you can create custom drop-down button for ARC command on new panel on the ToolSets palette:
At first, use Add drop-down button, then populate it with command in the order you need.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
