Cannot select then perform action...???
Message 1 of 32
All of a sudden I cannot select an object prior to keying in my action.
For instance, if I click on an object, then type "E-Enter" I have to select the object AGAIN and then click enter AGAIN.  Obviously you can normally select an object either before keying an action (and the action is performed on the selected object) or you can type the command first, then select the object.  All of a sudden CAD is forcing me to do the latter.
Any suggestions?  I have re-started, etc.
Replies (31)
Message 21 of 32
maxim_k
Josep,
From your screenshot I see you are using AutoCAD for Windows, but this is AutoCAD for Mac Forum.
Anyway, let's go further.
Try to disable all "Auto" and "Search" options in command line, then test command aliases.
What results do you get?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 32
Maxim,
When I disabled all Auto and Search options and tried troubled command
aliases I got the same result: previously selected objects are removed from
the selection set.
I did not realize this was a Mac forum,I am sorry. If I cannot continue in
this forum, could you suggest me the proper one?
Thank you,
Josep
Message 23 of 32
maxim_k
Josep,
AutoCAD for Windows Forum is here:
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
BTW, have you tried to Reset AutoCAD to defaults?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 32
Maxim:
I did reset to defaults with no improvement. Now I am going to do a clean uninstall, and then I will reinstall AutoCAD.
You have been very patient and helpful.
Thanks a lot!
Message 25 of 32
maxim_k
Can you check your keyboard also?
I mean if you have an opportunity, try to replace temporary keyboard on your machine, if it is laptop, then find external USB or Bluetooth keyboard.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 26 of 32
That's very helpful. I don't get it, why does autocad do that? It randomly turns something off or switches something to different option. I wish it stayed the way i set it to be.
Message 27 of 32
HATE IT when it does that
Message 28 of 32
maxim_k
Hi Denis,
Usually this happens when AutoCAD crashes or hangs (and you need to Force Quit it).
But believe me or not, I had such issue only once in the whole time I use AutoCAD for Mac (7 years).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 32
Solved the issue. Thanks a lot
Message 30 of 32
Are you trying to change the line color of a block?
Yes?
Then you have to double click on the block first to get into the
block editor; then you can change the color of the block's line in
the block editor only through it's property dialogue box.
Message 31 of 32
Out of curiosity, how would one accomplish the same change to without using the typed 'PICKFIRST' command? In other words, can this variable be set through the user-interface by pointing and clicking in Workspace Customization or Options?
Message 32 of 32
maxim_k
Welcome to Autodesk Forums!
Hi Alex,
Although there is no UI element for such customization, but here is what might help:
- set PICKFIRST=0 at the command prompt
- draw line
- select it and hit Delete key on keyboard
- you should see this alert:2019-04-19_07-12-23.png
Check "Always perform.." and pick on YES.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
