I've been trying to install AutoCAD for a few hours and it keeps failing. I've already tried everything on there: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle... multiple times. I've installed the licensing server manually too.
The error is always occurring around 93% then reverts back to 0%. Here is part of the log:
2022-04-19T19:58:31.870 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ] Ending Installation of (upi2: {1E260342-CCEE-395E-B0DA-2F5246C63F12} name: AutoCAD 2023 for Mac ) .Total operation time: 1.123796min7sec427ms
2022-04-19T19:58:31.870 [Install Manager: 10347, 0x30a5ac000] [InstallManager DEBUG] [ Notify ] Sending Response On IPC channel: {"command":"PROGRESS","response":{"Package":{"UPI2":"{1E260342-CCEE-395E-B0DA-2F5246C63F12}","progress":"90.099998"},"action":"INSTALL","applications":[{"UPI2":"{84D1B0D6-B7B1-32D7-87F2-C14AB88A8F6A}","UpgradeCode":"{CEBC9E18-6927-348C-B9E7-6A1A75F49C13}"}],"bundleUPI2":"{EA0E78B5-DE74-3C81-8130-D458BFCD0C4B}"},"source":"DDA_IM","target":"DDA_CORE","version":"DDA_V1"}
2022-04-19T19:58:31.873 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ] Starting Installation of (upi2: name: AutoCAD 2023 for Mac )
2022-04-19T19:58:31.873 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [CommandHandler] [ Install ] Command Handler Install called...
2022-04-19T19:58:31.874 [Install Manager: 10347, 0x30a5ac000] [InstallManager DEBUG] [CommandHandler] [ HandleRequest ] Executing package install command: "/var/folders/lt/vz_s_3qn0ds445f5_683sp240000gn/T/AppTranslocation/8FFDE533-5859-48EB-9BB7-008792D03066/d/Install Autodesk AutoCAD 2023 for Mac.app/Contents/Helper/Setup.app/Contents/MacOS/../../../ObjToInstall/postInstallODISMaster.sh" mac-pro
2022-04-19T19:58:54.456 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ] Fail when performing Installation of (upi2: name: AutoCAD 2023 for Mac )
2022-04-19T19:58:54.456 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ HandleInstallFailure ] Failed to install Package (upi2: {1E260342-CCEE-395E-B0DA-2F5246C63F12} name: AutoCAD 2023 for Mac ) Error Code: 112 Exit Status: 2
As you can see the error always occurs when running postInstallODISMaster.sh. I have not been able to find that file to inspect what it's doing presumably because it's being removed by the installer when it cancels the installation. Using a Macbook Pro M1. Never installed any Autodesk products before today. Can you help?
Thank you.
