Can't install AutoCAD 2023 - Error 112
Keagel
Message 1 of 15
Keagel
I've been trying to install AutoCAD for a few hours and it keeps failing. I've already tried everything on there: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle... multiple times. I've installed the licensing server manually too.
The error is always occurring around 93% then reverts back to 0%. Here is part of the log:
2022-04-19T19:58:31.870 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ]   Ending Installation of (upi2: {1E260342-CCEE-395E-B0DA-2F5246C63F12} name: AutoCAD 2023 for Mac ) .Total operation time: 1.123796min7sec427ms
2022-04-19T19:58:31.870 [Install Manager: 10347, 0x30a5ac000] [InstallManager DEBUG] [ Notify ]   Sending Response On IPC channel:  {"command":"PROGRESS","response":{"Package":{"UPI2":"{1E260342-CCEE-395E-B0DA-2F5246C63F12}","progress":"90.099998"},"action":"INSTALL","applications":[{"UPI2":"{84D1B0D6-B7B1-32D7-87F2-C14AB88A8F6A}","UpgradeCode":"{CEBC9E18-6927-348C-B9E7-6A1A75F49C13}"}],"bundleUPI2":"{EA0E78B5-DE74-3C81-8130-D458BFCD0C4B}"},"source":"DDA_IM","target":"DDA_CORE","version":"DDA_V1"}
2022-04-19T19:58:31.873 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ]   Starting Installation of (upi2:  name: AutoCAD 2023 for Mac )
2022-04-19T19:58:31.873 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [CommandHandler] [ Install ]   Command Handler Install called...
2022-04-19T19:58:31.874 [Install Manager: 10347, 0x30a5ac000] [InstallManager DEBUG] [CommandHandler] [ HandleRequest ]   Executing package install command:  "/var/folders/lt/vz_s_3qn0ds445f5_683sp240000gn/T/AppTranslocation/8FFDE533-5859-48EB-9BB7-008792D03066/d/Install Autodesk AutoCAD 2023 for Mac.app/Contents/Helper/Setup.app/Contents/MacOS/../../../ObjToInstall/postInstallODISMaster.sh" mac-pro
2022-04-19T19:58:54.456 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ PerformOperation ]   Fail when performing Installation of (upi2:  name: AutoCAD 2023 for Mac )
2022-04-19T19:58:54.456 [Install Manager: 10347, 0x30a5ac000] [InstallManager INFO] [ HandleInstallFailure ]   Failed to install Package (upi2:  {1E260342-CCEE-395E-B0DA-2F5246C63F12} name: AutoCAD 2023 for Mac )  Error Code:  112  Exit Status: 2
As you can see the error always occurs when running postInstallODISMaster.sh. I have not been able to find that file to inspect what it's doing presumably because it's being removed by the installer when it cancels the installation. Using a Macbook Pro M1. Never installed any Autodesk products before today. Can you help?
Thank you.
Replies (14)
Message 2 of 15
wei503
Hi @Keagel ,
Can you please email to feedbackacadmac@autodesk.com with all the following logs:
/Users/<username>/Library/Logs/Autodesk/ODIS/
/var/log/install.log
Wei
Wei Ma
AutoCAD QA Manager
Message 3 of 15
Keagel
Thank you for the reply! I wasn't aware there was another log file in /var/log so I checked it out and found this:
2022-04-20 11:10:40+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:40.571 postinstall[23462:162760] AdskLicensingService is not running...
2022-04-20 11:10:40+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:40.571 postinstall[23462:162760] The AdskLicensingService is not ready.Try again...
2022-04-20 11:10:45+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:45.585 postinstall[23462:162760] AdskLicensingService is not running...
2022-04-20 11:10:45+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:45.587 postinstall[23462:162760] The AdskLicensingService is not ready.Try again...
2022-04-20 11:10:50+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:50.713 postinstall[23462:162760] AdskLicensingService is not running...
2022-04-20 11:10:50+02 MacBook-Pro package_script_service[9678]: ./postinstall: 2022-04-20 11:10:50.713 postinstall[23462:162760] The AdskLicensingService is not ready.Try again...
Meaning that the service wasn't actually running. I reinstalled the service again, started it with
launchctl load /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
 instead of using sudo and this time the installation went through. Thank you!
Message 4 of 15
wei503
Awesome! Hopefully your findings will help others too.
Wei Ma
AutoCAD QA Manager
Message 5 of 15
hilwasilmiazzahra
Community Visitor
Community Visitor
where you put this one?
 because we have same problem, but until now i cant fixed that. please help me
Message 6 of 15
maxim_k
Hi @hilwasilmiazzahra .
It is Terminal command.
You need to launch Terminal app and use this command in it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 15
oleg0085
Observer
Observer
I enter your command, it gives me this(
Warning: Expecting a LaunchAgents path since the command was ran as user. Got LaunchDaemons instead.
`launchctl bootstrap` is a recommended alternative.
Message 8 of 15
maxim_k
HI @oleg0085 ,
Have you tried to run that terminal command as admin?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 15
oleg0085
Observer
Observer
yes
Message 10 of 15
fabio.angeliniLMREN
Community Visitor
Community Visitor
Hi Every One and Nice to meet you all,
i have the same problem a nothing seems working as solution,
Can anyone help me?
Thank YOU
Message 11 of 15
vikramaditya.ug180670
Community Visitor
Community Visitor
Did we find any solution ?
Message 12 of 15
maxim_k
Hi @vikramaditya.ug180670 ,
The solution seems to be in >>>>>this<<<<< post.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 15
RachelGomez161999
To solve the issue, verify the following suggestions one by one:
Uninstall and re-install the Autodesk On-Demand Install Service (ODIS) component manually
Go to the Windows Services.
Press the Win + R keys on your keyboard. ​​​​​​
Type "services.msc" in the Run window and hit Enter or press OK.
Stop the service "Autodesk Access Service Host".
Go to C:\Program Files\Autodesk\AdODIS\V1.
Launch "RemoveODIS.exe" as admin (right click > run as administrator), if it exists. Otherwise remove manually all the content in the folder.
Download and install the latest version of the Autodesk On-Demand Install Service (ODIS).
Run again the Autodesk product install.
Recreate the Custom Install image
If you are installing using Custom Install from the Autodesk Account, recreate the install package and try again to install.
Use the latest available Installation from Autodesk Account
Download and install again using a different install method.
Rachel Gomez
Message 14 of 15
wei503
@RachelGomez161999 your solution is for Windows, and here we discuss macOS.
@vikramaditya.ug180670 , Check this post, and let me know if you run into problems.
How to deploy AutoCAD for Mac
Wei Ma
AutoCAD QA Manager
Message 15 of 15
maria_francoYS5UN
Community Visitor
Community Visitor
Can you help me as well?
As I double click the installation file, it starts dowloading, as soon as it is in 10% it crashes and the process just quits, but does not say anything about a report.
