Can LAYMCH be set to move objects to a block's insertion layer
chris.vriend
chris.vriend
In AutoCAD for Mac, when the LAYMCH commands is used and a block is referenced, it appears to consistently move subject objects to 0  instead of the layer in which the block is inserted. AutoCAD for PCs does not work this way.
Is it possible to change this somehow?
maxim_k
Hi Chris,
You already asked this question a year ago:
https://forums.autodesk.com/t5/autocad-for-mac-forum/laymch-is-not-moving-objects-to-a-block-s-inser...
Unfortunately, nothing has changed since then - the bug is still here.
BTW - I always use MATCHPROP command, even if I need to change only objects layer.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
chris.vriend
That's a shame that no one has addressed this, despite the number of updates. I can't imagine it is intentional that the different versions of AutoCAD work so differently, but I suppose that using MATCHPROP instead will be a good approach.
Thanks.
