Hi, camera command dosen`t appeare in my AutoCAD for Mac. When I type camera in the comand line there`s only 2 options: cameradisplay and cameraheight. Does anybody know what can I do?
Solved by maxim_k. Go to Solution.
Welcome to Autodesk Forums!
HI,
CAMERA command is not available in AutoCAD for Mac.
If you need to create camera-like perspective view, you can enable perspective view in 3DORBIT command (use context menu to change from Parallel to Perspective).
You can also enable Perspective view with in-canvas viewport control (upper left corner of current viewport).
If you need to set "camera" parameters with more precision, you can use DVIEW command.
Don't forget to give the name to perspective view you created - this will allow to find your "camera" quickly.
Maxim
How do you render to a motion path without having a camera to link to a path???
¿This is a joke not...? This tool is a garbage...Sure,
It's a shame that you insinuate that it is a useful and intuitive tool . It is painful . Please solve this and the program AutoCAD for Mac has a " camera " tool like windows .
