cad2017 for mac 2017 Las file import Layer state manager
Message 1 of 11
cad for win las file to import and export     but   cad2017 for mac  —— Layer State manager no import and export
Where can I find it?????
hlep me!
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Message 3 of 11
My goodness! This need to export the LAS file and then import the LAS file in the new dwg file and then save the dwg file can not be achieved in the mac I need cad for win to complete the operation and then import into the cad for mac
Message 4 of 11
maxim_k
Why not?
You can do this with stAte option of -LAYER command:
http://help.autodesk.com/view/ACDMAC/2015/ENU/index.html?guid=GUID-2C75A883-10CA-4B6C-96AC-BCD7A7794...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
You can copy pictures steps to me?
Thank you
Message 6 of 11
maxim_k
Here you are:
In the screencast above I imported 22 Layer Stare from the drawing "Test later state.dwg" to new drawing.
When AutoCAD asks the drawing from which you want to import Layer State, type ~ (tilde) on keyboard and hit Return, this will allow to show "Select drawing" window to select the drawing with Layer States you want to import.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 11
Thanks for maxim_k This is a very good solution Thank you for your reply.
But my partner gave me a LAS file without a dwg file so I need to find a partner to give me a dwg file that I can use.
Message 8 of 11
maxim_k
No, in the "Select file" dialog just change "File of type" filter on the bottom from DWG to LAS and select .LAS file from your partner.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 11
Thank you very much for your reply. Why can not I choose the file with reference to your steps?
Message 10 of 11
maxim_k
Looks like you are trying to use wrong symbol when you type from keyboard.
You need to enter "tilde" symbol:
https://en.wikipedia.org/wiki/Tilde
Don't use  Alt + N button combination, it gives wrong symbol.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 11
thank you very much .
"~" May have a certain relationship with the Chinese input method to switch the input method can be used normally.
