Cad Automatically saves as and makes many copies?
Message 1 of 21
I've been having this problem since the beginning of the semester (1 month) and I have no idea what started it. Every time I start a new drawing, (I use acad.dwt) and save it, cad starts automatically saving versions of it whenever it feels like. In the folder that I saved the drawing in, new ones start showing up. For instance, if the file was called house.dwg, a house 2.dwg, then house 3.dwg just start showing up in the folder. As you can see in the attached picture, it has gone up to 21. The only file that I ever saved or saved as is "moodel.dwg" (ignore the stupid name). I noticed while taking that screenshot that it is also happening to my sketchup files, apparently? So it might be a Mac problem. It has happened to every single file for the past month. It started when I was running Yosemite and Autocad for Mac 2015. I upgraded to both El Capitan and Autocad for Mac 2016, thinking one of those would solve the problem. But alas, it didn't.
If anyone has any ideas please help me out! I'm running out of patience!
Replies (20)
Message 2 of 21
maxim_k
Welcome to Autodesk Forums!
Looks like you have permission problems with this folder. AutoCAD cannot overwrite existing files in it.
Have you tried to create another folder inside your Home folder and test AutoCAD behavior?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 21
By home folder do you mean like in the autodesk folder that stuff autosaves in? I will try that! Thanks
Message 4 of 21
maxim_k
Home folder on Mac:
http://m.dummies.com/how-to/content/the-home-folder-in-os-x-yosemite.html
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 21
shawnmayers
Help!  I have this problem too.  I am running autuocad 2015 mac on sierra osx.  It is making me crazy.
Message 6 of 21
maxim_k
I believe you are working with DWG files placed in the folder which is connected to iCloud some way - this could be iCloud Drive folder or Documents and Desktop folders connected to iCloud via iCloud pane in macOS System Preferences.
If I'm right, than it is knowing issue and the only one workaround is to keep drawings you are working on in the folder which is not connected to iCloud.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 21
Emmsleys
Did the suggestions made by Maxim help ?
Post back with any new updates or select Accept as Solution if any  post in this thread resolves your issue.
Sarah Emmsley
Technical Support Specialist
Message 8 of 21
shawnmayers
iCloud backs up every file on my Mac, I cannot select which files not to back up. Plus, auto cad crashes so many times, I need the backup. I just want auto cad to stop making a new file every time I hit “save” or close a file.
Shawn Mayers
shawnmayers@groundswelldesigns.com
401.439.8763
http://www.groundswell.design/
http://www.houzz.com/pro/shawnmayers/groundswell-designs
Award winning landscape design
Message 9 of 21
maxim_k
Which macOS version do you have on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 21
shawnmayers
I have a brand new power book 15" running Sierra
Shawn Mayers
401.439.8763
http://www.houzz.com/pro/shawnmayers/__public
Message 11 of 21
maxim_k
Which release exactly?
10.12.1, 10.12.2 or 10.12.3
I'm asking because I just tested on my side with AutoCAD 2015 and AutoCAD 2016 on 10.12.3 and cannot reproduce the issue with iCloud Drive.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 21
shawnmayers
Release 10.12.3
Shawn Mayers
401.439.8763
Message 13 of 21
maxim_k
Where do you save drawings on your Mac?
Can you provide full path?
Do you have this option enabled:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 21
shawnmayers
I save them in my documents folder> clients>client name> autocad.  Yes I do have that option enabled
Message 15 of 21
maxim_k
So looks like that there is a conflict between AutoCAD 2015 and iCloud sharing feature on Mac. You can treat this as a bug or defect.
The workaround is to put DWG files (and work with them in AutoCAD) outside Documents folder on your Mac and wait until the issue will be resolved by Apple and Autodesk.
If you need to have a copy of your DWG files in iCloud you can copy them after editing to some folder connected to iCloud.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 21
maxim_k
Hi Shawn,
I forgot to ask you another question :
Have you installed the latest Update 4 for AutoCAD 2015 for Mac?
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2015...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 21
shawnmayers
Thanks for all your help on this.  I have updated autocad with update 4.  Since the icloud backs up all files, there is no way around this.  I do hope that autodesk figures this out soon as it is a big problem.  At the end of the day, I have dozens of extra files that autocad automatically created.
Message 18 of 21
maxim_k
Unfortunately now I haven't access to AutoCAD 2015 as it is installed on another Mac. I tested only 2016 and 2017 versions.
Tomorrow I'll be able to test AutoCAD 2015 on that Mac which runs under Sierra.
I will be back with the results.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 21
maxim_k
Hi Shawn,
I tested 2015 version on Sierra on another Mac in another place. I also tested 2016 and 2017 versions on that Mac.
The result was ....
I have the same issue as you (many copies of DWG files which are created on save in AutoCAD) on this Mac in the another place.
So it looks like the issue is related to the Internet connection. In my case I think that the Internet connection on that new place is not so stable (fast ?) as in the place where the issue is not reproducible.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 21
shawnmayers
I don't think it's related to internet connection.  It happens every time I hit save or close a file.  No other programs I run do this, so it must be autoCAD-specific.
