Bold text PDF issue
Bold text PDF issue
doug_williamsLAFP5
Message 1 of 8
Bold text PDF issue
doug_williamsLAFP5
When PDFing some title block text needs to appear in bold.
It looks correct on the DWG paper space, but not once on the PDF.
Any thoughts?
AutoCAD LT 2021 Mac
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Font substitution in your PDF viewer perhaps: what font is that?
Message 3 of 8
doug_williamsLAFP5
Arial Bold.
Should be no issue in PDF viewer, standard font.
Message 4 of 8
pendean
Community Legend
Community Legend
Arial Bold, is, well BOLD, not to be confused with ARIAL: your PDF looks absolutely correct with this information.
Message 5 of 8
maxim_k
Hi @doug_williamsLAFP5
Have you installed >>>>this<<<< Hotfix?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 8
Did you ever figure this out by chance? I'm currently having the same issue although I am using a different font.  Looks bold in the .dwg but as soon as I open the .pdf all the text looks same none if it is bolded.
Message 7 of 8
pendean
Community Legend
Community Legend
>>>....Looks bold in the .dwg ...<<<
@Anonymous TTF fonts can look bold if they have a Z-setting.
Or this is your issue https://forums.autodesk.com/t5/autocad-for-mac-forum/bold-text-pdf-issue/m-p/10096155#M40457
What investigating have you done so far?
Message 8 of 8
maxim_k
Hi @Anonymous,
What font you are using?
Is it one of the default macOS fonts?
Please specify also your AutoCAD version and macOS version.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
