Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I just updated my Mac to Big Sur 11.4. Is Autocad and Autocad LT compatible with this version?
Hello designer1XH9YR,
I recommend you reviewed these links from Autodesk:
System requirements for AutoCAD for Mac
System requirements for AutoCAD LT for Mac
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Base on Determining the model on a Mac computer:
"The AutoCAD for Mac system requirements refer to a model identifier when describing the minimum or recommended Mac models to use with AutoCAD for Mac."
Emilio Valentin
Another option is to ask in the Installation Forum.
Emilio Valentin
Hi All,
I have an imac 2015 with Big Sur macOs 11.4. it meats all the operation requirements to run Autocad for Mac except it is not an imac 8.1. Does anyone now if Autocad for Mac will run on my computer?
Thank you
Hi Rebecka,
What AutoCAD for Mac version do you have?
If you have AutoCAD for Mac which is supported on macOS Big Sur - 2019, 2020, 2021 or 2022 - it will run on your iMac 2015.
iMac 8.1 is the earliest supported iMac model.
