Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoLISP beginner
6 REPLIES 6
2491 Views, 6 Replies
AutoLISP beginner
I am falling at the first hurdle with AutoLISP. I am trying to load AutoCAD's text editor.
My instruction book says
Go to Tools> AutoLISP> Visual LISP Editor
But in the Tools dropdown there is no AutoLISP option.
Instead I can go straight to Load Application instead - but there is no AutoLISP there either.
I have read the other topics of AutoLISP on this board - but they too seem to be missing some information. And done a number of searches on the internet. Is there something missing in my program? I have tried with AutoCAD 2011 for MAC and now AutoCAD2012 for MAC.
What am I missing?
Thanks in advance.
6 REPLIES 6
brianchapmandesign
Command is "vlide"
"Very funny, Scotty. Now beam down my clothes.
Thanks for your reply... tried this but no luck yet:
So trying it with AutoCAD 2012 gives the following
error: VLIDE can't be invoked because an initialization file is missing.
Also on AutoCAD 2011 the error is: VLIDE disabled.
Edit...
Having read through some other posts it would appear that Visual LISP editor is not in AutoCAD for Mac - but there also seem to be discussions on AutoCAD for Mac where people ARE using it successfully. Is the Visual LISP editor - or perhaps a similar editor avialable for download?
How are people getting around this? Are you running parallel? Or through a text editor?
David_Stacey
Hi
I'm just using a text editor. BBedit is a good solution. It is important to note visual lisp is not supported in autocad for mac. Straight good-ol autolisp works fine.
maxim_k
You can also try to use one of these text editors (with parentheses checking support):
1. Free
Fraise - http://www.macupdate.com/app/mac/33751/fraise - it also support color coding for Lisp functions
TextWrangler - http://itunes.apple.com/en/app/textwrangler/id404010395?mt=12 - Mac App Store - you need to create special file for color coding for Lisp functions
Smultron (old version) - http://sourceforge.net/projects/smultron/files/smultron/3.5.1/Smultron-3.5.1.zip/download - it also support color coding for Lisp functions
2. Paid
Smultron 4  (new version) - http://itunes.apple.com/en/app/smultron-4/id450194894?mt=12  - Mac App Store
AutoLisp documentation:
AutoLISP Developer's Guide (.pdf)
AutoLISP Reference Guide (.pdf)
those are for AC 2012 for Mac but in most cases applied to AC 2011 for Mac
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thank you for all your responses.
I am currently doing OK with text editor - and will chose one of the colour coding ones for later.
Thanks for pointing out that the Mac AutoCAD doesn't have the Lisp Visual editor/IDE.  I will move to the Windows version (via Parallels).
FYI, TextWrangler & BBEdit have an AutoLisp "Language Module" for color-coding AutoLisp syntax, which can be found here:
http://www.barebones.com/support/bbedit/plugin_library.html
Very easy to install, and the color coding is very helpful.
Tags (3)
