AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD MAC- Show blocks description
2 REPLIES 2
karenMV87H
557 Views, 2 Replies
Hi, is there a way to visualize the blocks description of each of the object on a MAC? I currently have the most recent version of AutoCAD LT 2022.
I'm only able to get access and edit the description when I click on the block editor, but is there another way to access to blocks description?
Thank you
Karen
Tags (3)
Labels (1)
2 REPLIES 2
maxim_k
in reply to: karenMV87H
Welcome to Autodesk Forums!
Hi @karenMV87H ,
In AutoCAD LT on PC you can see block description in Design Center, but there is no Design Center on Mac.
So if you have LT version on Mac, you can view and edit block description only in Block Editor.
In full AutoCAD version on Mac you can get block description with AutoLISP:
(defun C:GetDesc ( / )
(setq ent (entget (car (entsel "\n Select a block... "))))
(setq bent (entget (tblobjname "BLOCK" (cdr (assoc 2 ent)))))
(setq desc (cdr (assoc 4 bent)))
(alert desc)
(princ)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
karenMV87H
in reply to: maxim_k
thank you!
