Autocad Mac Crash on startup Mac OS El Capitan 10.11.6
kristinabhalter
kristinabhalter
Can't open the program.
Tried multiple times.
Fresh stat from shut down.
maxim_k
Have you tried to reset AutoCAD?
if you need to reset AutoCAD options to default settings, you need to launch AutoCAD from Dock by holding Shift key on keyboard and clicking on AutoCAD icon (you need to hold Shift for at least a few moments after you click on icon).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
kristinabhalter
I thought about it, but I will have to re-do all my settings manually,
which will take some time.
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
maxim_k
OK, you can try to create new user account on your Mac, login to it and try to launch AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
If it will launch, than something is wrong with AutoCAD preferences in your main account. And there is no other way to solve the problem - only reset AutoCAD.
When you reset AutoCAD it creates backup archive of the old preferences and customizations, you can use it to restore CUI customizations.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @kristinabhalter
Before you try and reset your settings I would recommend that you log in as a new user on your system as suggested in this thread. Doing this you are able to test AutoCAD in a new user environment.
If the issue still occurs in the new environment post back in the thread and we can troubleshoot from there.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Following up on this thread, were you able to try the suggested steps.
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
Sarah Emmsley
