Hi all
I am running AutoCAD Mac 2015 on a Macbook Pro 15" Retina (late 2013) on Yosemite 10.10.4.
When quitting AutoCAD, the entire screen goes black and the only way to regain control is to power off and then on again.
Interestingly, the same thing occurs when quitting Google Earth.
I had the same problem when running the same apps on Mavericks, so I upgraded to Yosemite in the hope the problem would go away.
Has anyone else had similar issues? I know there are lots of discussions regarding weird graphics behaviour on the Macbook Retina models, but thought I'd test the water out here to see what you guys have experienced before I replace this Macbook Pro.
Cheers.
Solved by David_Stacey. Go to Solution.
Solved by maxim_k. Go to Solution.
Hello David,
To use AutoCAD for Mac 2015 on Yosemite, you need to install Updates. Did you install Update 1 & 2??
OK. So I have been running AutoCAD 2015 for Mac without automatic graphics switching enabled. This has (for now) fixed the problem.
Solution is: Turn off automatic graphics switching!
