Hi, when I export to pdf from a viewport, the pdf produced has a 'scratchy', grey quality to it. This seems to be caused by a google map image I have on one layer because if I remove it, the 'scratching' goes. Does anyone know why this might be? Thanks
Solved by maxim_k. Go to Solution.
Hi Maxim
Please see a screen shot of the pdf. The 'scratching' dissapears when I zoom in, but is present before this. Thanks.
I'm not sure I understand the solution you're suggesting. I have three sections to the drawing:
(1) The google PDF (bottom)
(2) An Ordinance Survey dwg of the area (middle)
(3) My drawing (top)
I would like it to print to pdf in this order without the 'scratching', so that the google layer is only seen where there is no (2) or (3) on top of it.
Hi Neil,
Please look at the attached PDF.
Is it what you need?
If yes, then I can explain the trick.
Morning Maxim,
It's the viewport A2 Entrances & Exits that sems to cause the issue when the google layer is under the other layers. To get around the issue, for the 'Arena' viewport, I move the google layer out of the way. It seems that when the google layer is in place, the scratching occurs.
I hope that makes sense.
Neil
It is here:
