Sorry if this was already asked, couldn't find it.
I have installed AutoCAD LT for Mac and also Fusion 360.
Fusion remembers my sign in credentials but I have to login every time that I launch AutoCAD.
Is there a way to avoid this and how?
In windows this doesn't happen.
Thank you.
Solved by geza.denes. Go to Solution.
Welcome to Autodesk Forums!
Hi Géza,
Please read this AKN article:
on Mac is here:
~/Library/Application Support/Autodesk/Web Services
You can also ask your question here:
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
thanks for the quick reply.
I have already checked that post.
I've deleted the login state.xml but the same thing happen when I restart or get back to work after the laptop is in sleep.
I don't have this issue in Windows as the Autodesk Desktop app manages the login there perfectly.
On the Mac the AutoCAD and also Fusion has exclusions in the firewalls and also the antivirus.
Fusion logs in correctly but AutoCAD LT is keep asking me to login every time.
If you have any other ideas, everything is welcomed.
Hi
I updated AutoCAD LT to 2022 version and the issue is sorted.
Looks like a clean install worked.
Thanks for your help.
