AutoCAD LT 2017 for MAC
aandreas16
Message 1 of 18
aandreas16
Constant crashing since using the 2017 version. Unbearable and proving impossible to work effectively. Waiting for an update to fix bug! Anyone else experiencing the same?
Accepted solutions (4)
Replies (17)
Message 2 of 18
Emmsleys
What OS are you running on the MAC?
Sarah Emmsley
Technical Support Specialist
Message 3 of 18
aandreas16
OS X Yosemite version 10.10.5
Message 4 of 18
john.vellek
Hi @aandreas16,
Some customers reported this issue when running on Yosemite.  The general recommendation is to go to the Apple store to check for OS updates. It appears that you might already have the latest updates for your OS.
Can you please confirm that your Mac also meets the system requirements?
Will you also please try creating a new user account on your Mac and logon with it to see if AutoCAD performs differently?
John Vellek
Message 5 of 18
Emmsleys
@aandreas16
If you could please try and update your OS and apply all updates to AutoCAD LT 2017.
Post back if you have any other questions.
Thanks.
Sarah Emmsley
Message 6 of 18
aandreas16
I've updated my OS. From what I can see my AutoCAD software is fully up to date too.
System requirements are attached. I am hoping the OS update has done the trick. I'll keep you posted as to whether it was the correct solution.
Message 7 of 18
aandreas16
System details are attached with respect to system requirements. I am hoping the OS update has done the trick. I'll keep you posted as to whether it was the correct solution.
Message 8 of 18
Emmsleys
To add, check your Autodesk account for the updates for AutoCAD LT 2017.
Let me know if you run into any other issues.
Sarah Emmsley
Message 9 of 18
john.vellek
Hi @aandreas16,
Did you check for all the updates for your AutoCAD LT? If so, do you find things to be more stable?
John Vellek
Message 10 of 18
aandreas16
All seems a lot better since the OS update - crashing very rarely. Thanks for all the assistance
Message 11 of 18
Tom_Janus
I am running Sierra 10.12.2 on a new Macbook pro 15" w/ touchbar.   Audocad for mac 1017 crashes every time I close a drawing wether I changed it and saved or not.
--TJ
Message 12 of 18
SteveHicks
I just purchased a license for AutoCad LT for Mac over the weekend.   It is so unstable, that it is NOT usable.   I have the latest update for OX Yosemite and I am running on a MacBookPro ver 11,5.
I have entered a support ticket with AutoDesk and will share what happens.   I have been using AutoCad LT for Mac 2012 on this same system for several years with no problems.   Hearing that I am not alone is comforting, but makes one wonder about this particular release.
Comments are appreciated.
Message 13 of 18
I am currently running Autocad 2017 LT for Mac on a late 2013 MacPro (OS X Yosemite, 10.10.5 3.5 GHz 6-core/16GB RAM/AMD FirePro D700) and for whatever the case may be it constantly crashes.
Work does not entail any 3D modeling or intense graphics demands on the system.  Is seems as time goes on working/drafting the crashing occurrences increase.  To the point that it is non productive time spent on client's dime/meeting contractual obligations.
I did see a couple of weeks ago a Hotfix 1 was issued.  Unfortunately it too had the same outcome -  the constant crashing of the application.
Are there similar experience with the non "LT" versions from Autodesk?
Any suggestions from technical staff or other dedicated individuals?
W
Message 14 of 18
john.vellek
Hi @Anonymous,
There are known issues with AutoCAD for Mac 2017 on this version of Yosemite. I suggest that you look for OS updates from Apple or consider moving to a newer version of your OS.
John Vellek
Message 15 of 18
SteveHicks
Thank you for your response.   I have completed the upgrade on my OS system and Autocad is now running smoothly.
I am now a happy camper.
Message 16 of 18
Thanks John,
In my search for answers and reviewing outcomes of suggested steps to resolve the "crashing" issues I "was" experiencing,  I found myself updating the OS to the latest version.  I did install the "Hotfix 1" prior to upgrading to Sierra but it did not resolve the issue.
Conclusion - simply upgrade your OS if you are planning to use the application = it works (+8 hours and no crashes)
I would do a little homework and confirm that your current applications will function as intended with the update. Often too many users follow direction without specific consideration to their own needs.
regards,
WTA
Message 17 of 18
@john.vellek wrote:
Hi @Anonymous,
There are knowon issues with AutoCAD for Mac 2017 on this version of Yosemite. I suggest that you look for OS updates from Apple or consider moving to a newer version of your OS.
Thanks John,
regards,
WTA
Message 18 of 18
john.vellek
Hi @Anonymous,
Unfortunately, OS incremental updates are out of my hands so a fix that works at one point in time will not work for all users.
I am glad that your update fixed the problem for you.
Thanks for contribution!
John Vellek
