Autocad Lt 2016
Autocad Lt 2016
Autocad Lt 2016
AutoCAD LT2016 for Mac.
Macbook Pro running OSX 10.10.5
Dowloaded and installed and activated.  But the program will not load.  The splash screen says loading - but the spinning rainbow keeps spinning.  The dock says programr is not responding.
Any Advice?
maxim_k
If you are absolutely sure about activation, than I think you need to try to reset AutoCAD as described here:
https://macacad.wordpress.com/2014/03/16/new-way-to-reset-autocad-for-mac-settings-2014-version-with...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks.  Well - I entered the codes for activiation and then the installation conitinued - so I'm assuming it was accepted.
I tried starting with shift+click and that didn't work.  I still get program is not responding.
BTW this link was for LT 2014 and I have LT2016 - are they the same?
Thanks.
maxim_k
Accepting serial number during installation doesn't mean that AutoCAD is activated. It should activate at first run, so looks like you have problem with activation.
Which licence type to do have?
Is this the first AutoCAD installation on your Mac? Or you already had AutoCAD installed?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
