AutoCAD LT 2016 for Mac "Application not responding"
Message 1 of 9
I've asked this question already, but, I just dowloaded and sucessfully installed my AutoCad LT (2016) monthly subscription to my Mac and when viewing the AutoCad icon it states (in faded text): "Application Not Responding." Do you have any solutions? Thanks!
@Anonymous,
john.vellek has edited your subject line for clarity:"Application Not Responding"
Replies (8)
Message 2 of 9
john.vellek
Hi @Anonymous,
Did you try applying Service Pack 1 also?
Which operating system are you running on your Mac?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 9
wei503
Please intall the SP1, then hold shift+click the AutoCAD Icon to launch it, this will force resetting AutoCAD. If the startup failure is due to corrupted config files, this solution should work.
If it still hangs, please get a sample file and attach here. To get the sample file, when AutoCAD hangs, open the Actifity Monitor, double click the AutoCAD process, click sample button.
Wei
Wei Ma
AutoCAD QA Manager
Message 4 of 9
john.vellek
HI christianarchitects,
I am checking back to see if my post or @wei503 helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 5 of 9
Hi I have the same problem when viewing the AutoCad icon it states: "Application Not Responding." I tried to follow your instructions but I don't understand them. Can you help me out?
Message 6 of 9
Message 7 of 9
john.vellek
HI dinta_madalin95,
Let's start by making sure that you have the latest updates applied. They can be downloaded from here.
Once you have installed the update then start AutoCAD while holding the shift key down. This will reset AutoCAD to default settings. Please post your results.
John Vellek
Message 8 of 9
Emmsleys
To add to this thread please double check that you have installed all updates for AutoCAD LT 2016. P
If you continue to have an issue after installing all updates post back in the thread and we can continue to troubleshoot.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 9 of 9
Emmsleys
Following up on this thread, were you able to resolve your issue? Could you possibly share that with us in this thread?
If you are still having an issue with AutoCAD the community and I will be more than happy to help.
Sarah Emmsley
